Gas Cap Release
Old Feb 12, 2003
RSX XTC's Avatar
RSX XTC is an unknown quantity at this point
Gas Cap Release
im from N.E. so the other day it snowed here right and i went out side to clean my car off i got it and i noticed i need Gas so i go to open the gas door by pushing the button, but i looked first and noticed it was covered in Ice. so i got some hot water to melt the ice so i can open it. ok that works Ice all gone.
But when i get in the car to check to see i press the Gas button and i hear a weird noise and the gas door dont open. i cant figure if maybe if the wire snapped. or if i came un hooked so to open the gas door i have to reach in on the left side of the truck and pull the button out by hand.
Is ther anyone that might know of how to fix this without having to go to a honda dealership or garage. any DIY would be great i cant find anything as of yet..
Help is Greatly Appreciated ( i sux opening your trunk and reaching inside to open the dam thing.. i feel Ghetto. LOL )
Old Feb 12, 2003
Ronin's Avatar
Ronin is an unknown quantity at this point
Sounds like your cable snapped. Probably best to take it in since it should be covered by warranty.
And also, I wouldn't recommend using hot water to de-ice parts of your car during winter. That sudden temperature change can't be good for your car's body and paint. And when that hot water ends up freezing eventually, you'll have an even bigger block of ice to deal with.
Old Feb 13, 2003
MangoEX's Avatar
Just Be
MangoEX should not be trusted
this happened to my friends car, the cable fell inside the quarter panel, just reach inside and put it back in
Old Feb 13, 2003
RSX XTC's Avatar
Unfortunatly my warranty ended at 36 k miles and i now have 39 k.. so that cuts out that. im not deicing with scolding hot water just semi warm.. also after i get it open i wipe the water with a towel. so it dont freeze again...
asfor the cable. it didnt fall down because its still connected inside i have to pull the cable itself for the door to open. its as if there is alot of slack in the wire all of a sudden. or that the wire snapped.
i talked to the dealership and they said they have never seen a broken wire in this situation for a 2001.. usually happens on older models
Old Feb 16, 2003
Macko's Avatar
Macko is an unknown quantity at this point
maybe the clip sinde the door fell off.. get someone to hold the lever doen while you push the left side of the gas door in.. it should open... my clip got lost once..
Old Feb 18, 2003
RSX XTC's Avatar
yeah i tried that before and when i press on the button the. little button im the gas area does not move. its as if the wire inside the cable snaped and there is no tension there.. first i thought it might just be frozen. but i warmed it up and i still get nothing
Old Feb 18, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
i suggest u take it to honda, should be a small problem...they shouldn't charge ya[IMG]i/expressions/laugh2.gif[/IMG][IMG]i/expressions/laugh2.gif[/IMG]
Old Feb 19, 2003
RSX XTC's Avatar
yeah im thinking that at this point that might be my only option.. but the Honda near me love slam you up the [IMG]i/expressions/moon.gif[/IMG] with prices
SimpleUser
Apr 24, 2021 02:54 AM
liagreenhalgh92
Jul 21, 2015 01:31 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
Hqly2001
22
Jul 12, 2015 06:44 PM
Bounddyy
Jul 8, 2015 11:22 AM
