Knocking from Koni's?
Old Feb 11, 2003
Khmi's Avatar
Khmi is an unknown quantity at this point
i just started hearing knocking nosies when i go over small little bumps at speeds under 35 mph, i dont hear it when im on the freeway or on big bumps. seems like it comming from the front drivers side, i can hear it and feel it on my sterring wheel and/or brake pedal. i have progress springs on also, just got the koni's about a month ago. has anyone else had this problem, what could be causing it?
any help would be great
[IMG]i/expressions/face-icon-small-confused.gif[/IMG]
Old Feb 11, 2003
Weaponx12o's Avatar
does it make a knocking/clicking noise when you turn the wheel too? i don't have konis so i don't know what might be wrong. maybe it's not tight enough? i'd get it checked out if i were you.
Old Feb 12, 2003
BIGLIMPDOG's Avatar
BIGLIMPDOG is an unknown quantity at this point
I have the same issue! I have stock struts and sprint springs! My car does it almost everytime when I shift hard or floor it! It makes like a pop noise that sounds like the transmission or motor or struts moved backwards! MY CAR IS FALLIN APART QUICK! But I think that it is the bushings that connect at the a arm and the under body front of the car! Or motor/transmission mounts! I will let you know when i get mine fixed! Im going to take it to honda and see what they say!
Old Feb 12, 2003
Khmi's Avatar
yeah it makes a noise when i turn the wheel. I'll go to the shop where i got my koni's installed.
Old Feb 14, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
yea same here...cause they have to mod the front strut to fit the knois....thats why
Old Feb 14, 2003
Mbow's Avatar
If it makes a noise when turning the wheel, the top-perch is not lined up correctly. That's is the reason you get the noise when turning the wheel. Our struts are a pain in the ****. I know, I changed mine 3 different times.
Old Feb 24, 2003
Intruder's Avatar
Intruder is an unknown quantity at this point
I am running koni's and H&R's and have this same problem, a kinda quiet ticking/knocking at slower speeds from the front drivers side. I took it to the dealer and they couldn't pinpoint it. I have checked all connections and bolts so at least I know it isn't toooo serious [IMG]i/expressions/face-icon-small-smile.gif[/IMG] Oh well, the price we pay for a quality suspension setup I guess....
Old Feb 24, 2003
Cyko's Avatar
Cyko is an unknown quantity at this point
our stock suspension tends to have problems [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Feb 25, 2003
MadSpeed's Avatar
MadSpeed is an unknown quantity at this point
Stock in general = problems
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
beanhead
Sep 24, 2015 12:04 PM
Styven Szastur
Sep 23, 2015 05:26 PM
curaze
Sep 22, 2015 08:27 AM
