Please help: noise coming from engine
Old Jan 28, 2003
I recently noticed a strange noise, almost like a whine, coming from the engine at idle. It only starts after the car has warmed up about ten minutes, and the noise is constant while being inline with the engine timing. Very strange why it does this. Does anyone know what is causing this? My car only has 8,700 miles.
Thanks
Old Jan 30, 2003
Devst8n's Avatar
Devst8n is an unknown quantity at this point
Hey gearbox try checking the tension of the belts under the hood. Chances are the rubber has stretched and it needs to be tightened. It would go away after warm up because the belt warms and sticks better as well...
If you arent as mechanically inclined take it to the dealership...should be under warranty
Old Feb 1, 2003
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
do you have a system in there? could it be alternator whine?
Old Feb 1, 2003
Silversleeper's Avatar
Silversleeper is an unknown quantity at this point
hmm... maybe u have one of those special factory freak Civics, yea.. these select few Civics came with superchargers in em!!!! okay.. being realistic now, i am see that u have a system installed ( a nice one at that!!). and that whine is usually only noticed at idle. check your audio installation. the power wire should be run on the opposite side of your vehicle the RCAs are running. if they run parallel and in close proximity, they power wire will interfere with the RCA sound signal.. thus.. the whine u r hearing.
Old Feb 2, 2003
Thanks for the help. It seems to only happen when its cold outside, so I'm thinking the belts. The stereo system has been there for 5-6 months and hasn't been a problem in the past. For now I'm ignoring it until something breaks and I can take it in for warranty service.
civicns
May 8, 2015 09:49 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
Sparty
Nov 15, 2001 04:55 PM
eX2ooo
Oct 5, 2001 12:19 AM
ernhole1
Aug 2, 2001 11:12 PM
