battery dying!?
battery dying!?
hi, i drive a 2001 civic si (ex) and lately my battery is dying... for example, i'm at the mcdonalds drive thru and i've been just sitting there in the car while it's on waiting for my food. i was waiting for like 5 mins. after i picked up the food and drive away. as i start drive away i stalled the car and i tried starting again, but it won't start... so i had to get someone to jump the car for me... the car's been doing this a lot lately....
so i dont know what's wrong with the car... is it not charging correctly? is it my battery? i went to my honda dealer for my tune up, i told them my problem... i asked them if it could be my alternator or battery... they said if it was my alternator, then a light in my dashboard would light up. but i never saw any light, so i guess that couldn't be the problem... they told me what they can do is do a battery check and that would cost me like 80 bucks! i said forget it, cause i can get a new battery for that price... so i just want to know if it's my car or the battery or anything else... thanks for the replies in advance!!!
Looks like your past the battery warranty period if your car is an 01, so that's not an option. Second thing to keep in mind is that the battery that comes with our cars absolutely sucks.
$80 to check your battery? Holy ****! That's nuts. You can take your car to Autozone or somewhere like that, and they will check your battery for free.
Quote
[hr]Originally posted by: zetaR
$80 to check your battery? Holy ****! That's nuts. You can take your car to Autozone or somewhere like that, and they will check your battery for free.[hr]
but i guess i can go somewhere else to get my battery checked... thanks!
Quote
-Kre
oh really? 3 months only? well i had mine for a while now... i have over 24000 miles on mine....
well i just went to somewhere to ask about my car and they said it's probably my cap and rotor...
Quote
[hr]Originally posted by: tamazoid
well i just went to somewhere to ask about my car and they said it's probably my cap and rotor...[hr]
Only problem with that is there is no cap and rotor used in our cars, the spark and majority of engine timing is computer controlled. Sounds like you might either have a bad battery(wont take a charge, go to Autozone for testing) a loose altenator belt or evena bad altenator. Those are the common things that go wrong when your car doesnt start aside from it being a starter/solenoid problem or other electrical issue.
Quote
[hr]Originally posted by: flotsamm
Only problem with that is there is no cap and rotor used in our cars, the spark and majority of engine timing is computer controlled. Sounds like you might either have a bad battery(wont take a charge, go to Autozone for testing) a loose altenator belt or evena bad altenator. Those are the common things that go wrong when your car doesnt start aside from it being a starter/solenoid problem or other electrical issue.[hr]
Quote
yea, i guess the best way is to just get them to check it out... whatever it is, it should be covered under warranty... if it's the battery, then i'll just buy a new one... thanks!!
well i found out the problem to my car... the battery just died... that's weird!! i only owned the car for like a year and a half and the battery died already!! i guess the factory battery sucks!! well anyways, i went back to the dealer and told them my problem and they did a bunch of test to see what's wrong and they found out it was the battery... so they just replaced it for free under warranty and that was it!
Quote
well i found out the problem to my car... the battery just died... that's weird!! i only owned the car for like a year and a half and the battery died already!! i guess the factory battery sucks!! well anyways, i went back to the dealer and told them my problem and they did a bunch of test to see what's wrong and they found out it was the battery... so they just replaced it for free under warranty and that was it![hr]
really? the car shut off? I thought the engine should be charging the battery when the car is running.
Did you have trouble starting the car with the old/broken battery?
Im also having a probnlem with my car, After car is left overnight, then started the next morning, first 30 minutes of driving has the idle very unstable, at neutral rpm drops to as low as 500. Can it be the battery?
I think we have the same prob. the battery
jzhartman
22
Jul 23, 2015 10:42 PM
Smokahontas123
Jul 22, 2015 10:07 PM
