question about a click/creaking clutch
Old Jan 5, 2003
Alex1's Avatar
ok i dont abuse my car and do burn outs and stuff. but at the end of the night when im on my way home, the clutch starts clicking or creaking whenever i release it. it dissapeared for a while and tonight it came back again. this is during cold weather. does anyone have any input on this? my car has 5k miles on it.
Old Jan 5, 2003
andoy's Avatar
andoy is an unknown quantity at this point
haha.. i have thesame problem.. i dont know wut it is, but all i did was pump the clutch until it disappeared... so far it hasnt come back...
Old Jan 5, 2003
Alex1's Avatar
thanks i might just try that... mine disappeared the next day. but it came back last night. its weird.
Old Jan 5, 2003
Mbow's Avatar
Something just needs to be lubed most likely. You can get down under there and push the clutch with your hand while you listen for where the noise is coming from. Then, just lube it.
Old Jan 5, 2003
OyD's Avatar
OyD
OyD is an unknown quantity at this point
there is a service bulletin for that. take it to your dealer
Old Jan 5, 2003
Alex1's Avatar
thanks... hmm service bulletin? do u know anymore about this thing?
Old Jan 6, 2003
OyD's Avatar
OyD
Bulletin
Old Jan 6, 2003
Mbow's Avatar
Just because there is an SB it doesn't mean that it is the problem or even applies in this case. If I was you, I would try listening for where the noise is coming from. I had the same problem and it had nothing to do with that SB. Had an accord that just needed the return spring lubed every so often. L
Old Jan 7, 2003
01civicboi's Avatar
01civicboi is an unknown quantity at this point
i have that problem too. i'm pretty sure it's the clutch PEDAL and not the clutch itself
Old Jan 19, 2003
jay2's Avatar
jay2 is an unknown quantity at this point
U NEED TO NOW IF IT COMMING FROM THE CLUTCH MASTER CYLINDER ROD OR THE PEDAL ITSELF....IF IT THE PEDAL U CAN LUBRICATE WITH LIEK SOEM WD040 OR SOEM 4 WAY SPRAY FOROM HONDA...IF IT S THE ROD THEN U NEED TO REPALCE THE CLUTCH MASTER CYLINDER...IF U DECIDE TO DO IT YOURSELF...DOTN FORGET TO BEEELD THE CLUTCH MASTER....SEE OF THAT HELPS...DUCE!
Old Jan 19, 2003
Boilermaker1's Avatar
Jap-Euro Fusion
3 places it can come from... I know this because it took Honda 3 tries to find it. 1 is the pedal itself. That can be fixed by yourself with the above mentioned WD-40. 2nd is the master cylinder fitting. There's a TSB on that. 3rd (where mine was squeaking) is the bearing that moves the fork that goes into the clutch housing and actually triggers the clutch. I don't remember exactly what was done, but the slave cylinder was removed and some bearings were repacked and some bushings in the linkage were replaced. Finally solved the problem. It happened to me when it was cold too... reason... they didn't use grease that was good in low temperature. They re-packed them with the same stuff that goes in the Odyssey sliding door bearings which is rated at much colder temps.... and it worked like a charm.
Edited: spelling
cukaracha
30
Jul 26, 2015 12:01 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
muttleytm
Jul 8, 2015 04:13 PM
Youshoe
Air Conditioning
Jul 8, 2015 09:49 AM
671civicLX
Jul 4, 2015 04:02 PM
