Grinding gears with clutch in
Old Dec 22, 2002
Sweetpants's Avatar
Sweetpants is an unknown quantity at this point
ive had a problem with the gears grinding when i put the car back into first when the clutch is pushed all the way in. its only happened when the car is still rolling. i didnt think too much of it at first beause this is the first car ive driven thats a stick, but my friend was driving it yesterday and the same thing happened to him. is there something wrong with my transmission????
Old Dec 22, 2002
CarbonFly's Avatar
How fast are you rolling when you put it into 1st?
I've never ground when putting it into first with the clutch in, but it is tough to put into gear while rolling in between 10-20 mph. Are you forcing it into the gear?
Old Dec 22, 2002
Mbow's Avatar
Sounds like the tranny is trying to lock you out if you ask me. If you are already rolling you should be going to 2nd anyway. First is strictly to get the car moving. Once you're moving, you shouldn't go back to first.
Old Dec 22, 2002
Sweetpants's Avatar
its usually at about 5-10 mph when im getting ready to stop....like at a stop sign
Old Dec 23, 2002
odie's Avatar
odie is an unknown quantity at this point
i never get that when going into 1st, but if i'm rolling backwards, and shift into reverse, i get a gear grind. i have to brake to a complete stop, then shift into reverse to not get a grind. i dont know why it would grind if i'm already rolling backwards in the first place, but oh well...
Old Dec 23, 2002
Mbow's Avatar
Quote
[hr]Originally posted by: odie
i never get that when going into 1st, but if i'm rolling backwards, and shift into reverse, i get a gear grind. i have to brake to a complete stop, then shift into reverse to not get a grind. i dont know why it would grind if i'm already rolling backwards in the first place, but oh well...[hr]
Every manual to my knowledge does that when going into reverse while the car is moving. It's completely normal and nothing to worry about. Just put it in reverse while the car is stopped or barely rolling.
Old Dec 23, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Mine does it after it has been sitting out in the cold garage all night...after a few shifts its better...you have to watch too, it is quite possible you are going to fast to downshift to a gear, hence the reason you are locked out or grinding gears...
2Hottie
Old Dec 24, 2002
Sweetpants's Avatar
thanks for the comments/advice, just got the revo ss, so ill have to get used to that now
Old Dec 26, 2002
RoBBUsaF's Avatar
RoBBUsaF is an unknown quantity at this point
Robins Air Force Base? Are you that guy with the other black civic ex in the dorms?
haha.
Old Dec 26, 2002
mohawkboom's Avatar
Gears don;t grind..their all stationary.. it's the dog teeth that grind.. keep note that first gear is not syncro meshed...to properly shift into first with the car rolling you must double clutch.. This gets the transmittion turning at the same speed as the engine for a moment..
Old Dec 27, 2002
Falcon's Avatar
Falcon is an unknown quantity at this point
no kidding?? first doesnt have a syncro?
didnt know that!
EDIT: then again.. i have an auto so why would i know that
mjdiaz89
Jun 21, 2016 09:26 PM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
06Si_Girl
Jul 12, 2015 12:08 PM
Steinar.D
Transmission
Jul 10, 2015 01:38 AM
1khilari
Jul 9, 2015 08:12 PM
