shaking
Old Dec 19, 2002
jamesbbh's Avatar
jamesbbh is an unknown quantity at this point
shaking
why does my car shake at 55-60? the whole car vibrates like its on a bumpy road and i was wonderinf why, o its only at 55-60 anything over or less than that fine
Old Dec 19, 2002
rackness's Avatar
rackness is an unknown quantity at this point
your wheels could be out of balance
Old Dec 19, 2002
rackness's Avatar
also u should have your alignment checked
Old Dec 19, 2002
RedDragon333's Avatar
Quote
[hr]Originally posted by: rackness
also u should have your alignment checked[hr]
what he said
Old Dec 20, 2002
KeNsHiN's Avatar
LEVA
Quote
[hr]Originally posted by: RedDragon333
Quote
what he said[hr]
What you said!
Old Dec 20, 2002
inca's Avatar
inca is an unknown quantity at this point
The mouse running on the wheel inside the engine starts to lose his footing once u get up to around 60.
Old Dec 20, 2002
Quote
[hr]Originally posted by: inca
The mouse running on the wheel inside the engine starts to lose his footing once u get up to around 60. [hr]
LMAO
Old Dec 20, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Get that alignment checked out I have aftermarket rims and even at 100 my car doesn't vibrate.
Nick
Old Dec 20, 2002
theguysmiley's Avatar
theguysmiley is an unknown quantity at this point
Every front-drive car I've ever owned has done that. I think it's pretty much normal. If you don't like it then either follow what everybody else said, or buy a 350Z, which is rear wheel drive, then you won't have that problem anymore .
Old Dec 21, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
It's most likely a wheel balancing problem. Alignment problem would not necessarily lead to shaking, but balancing problems almost always do. Does your steering wheel shake badly too?
Quote
[hr]Every front-drive car I've ever owned has done that. I think it's pretty much normal.[hr]
Then you're pretty much saying every front wheel drive car you've owned has had a wheel balancing problem. None of my previous 3 front-wheel drive cars have ever done this.
Old Dec 21, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Quote
[hr]Originally posted by: Ronin
Quote
Then you're pretty much saying every front wheel drive car you've owned has had a wheel balancing problem. None of my previous 3 front-wheel drive cars have ever done this.[hr]
Exactly...
Wheel balancing and aligment must be done.
Have you locked ur wheels lately? My friend locked his wheels several times so he has totally uneven tire wear which caused shaking.
Old Jan 24, 2003
LOXLEY's Avatar
LOXLEY is an unknown quantity at this point
its definately a wheel balance problem. alignment problems rarely have anything to do with the steering wheel shaking. alignment problems are associated with uncommanded steering or drifting within the lane.
Old Jan 24, 2003
solar's Avatar
solar is an unknown quantity at this point
Just like Ronin and Loxley had said," Alignment will not cause a vibration problem." All that will happen is if your alignment is out is the car will drift or pull to one side and/or cause tire wear. Sounds like you have a wheel balance problem which can be caused by a wheel weight falling off or hitting a major pot hole or the like. Or its possible, (but unlikely) that a axle shaft is out of balance or maybe a CV joint is going bad or possibly a wheel bearing is going out.
But alignment will not cause a vibration.
Old Jan 24, 2003
iluvbritney's Avatar
iluvbritney is an unknown quantity at this point
u got rims? lowered? go get some hub rings...9 bucks will fix ur problem
mgrantaz
General
May 2, 2022 05:40 PM
Solo Flow
Oct 4, 2015 07:52 AM
SolidHollow
15
Sep 13, 2015 11:18 AM
Mannimarco
Sep 7, 2015 10:01 PM
rainman15
Sep 6, 2015 11:10 AM
