Moisture in Headlight - WILD SOLUTION!
Old Nov 22, 2002
Civicized's Avatar
Civicized is an unknown quantity at this point
Hey, guys,
I put my previous post about foggy headlight, and then thought about a wild solution:
I really do not want to take off the whole headlight, blow-dry it, seal it - sounds like alot of hassle. So, I thought of something else. What IF one takes out the parking light bulb and the main bulb, and then, since the blow dryer will not fit into the main light opening, instead, one uses the air pump at the gas station to blow into the main bulb opening.
The air-pumps are small, alternatively, one can put a piece of hose on top of it, and stick the hose into the headlight. Sounds like a quick workable solution - has anyone ever tried this?
Civicized
Old Nov 22, 2002
BIANCA's Avatar
BIANCA is an unknown quantity at this point
you will probably get a bunch of dust/dirt in there.
my headlights were foggy right after i did the DIY clears. i just drove every day with my headlights on all the time and they cleared up after about 3 weeks. never fogged up again.
Old Nov 23, 2002
dragoon's Avatar
doesn't sound like a very good idea. just open 'em, geez [IMG]i/expressions/face-icon-small-tongue.gif[/IMG]
Old Nov 28, 2002
NickDaMans02Civic's Avatar
NickDaMans02Civic is an unknown quantity at this point
Yeah I wouldn't recommend it but thats just me just open them up it doesn't cost that much for sealant
Nick
Old Nov 28, 2002
matt007's Avatar
matt007 is an unknown quantity at this point
Compressed air will have more water in it.
Try this: Pull a bulb out, buy a brand new SPONGE and cut it so it will fit in the hole with some of it sticking out. In a day or so it will suck the moisture out, and while it is in the hole, prevent any more moisture from getting in. Sounds weird, but it will work. New sponges will dry up the air around them (don't ask me how!)
Matt
Old Nov 28, 2002
Boilermaker1's Avatar
Jap-Euro Fusion
Well, how are you going to put the hose in and still trigger the air? The air hose at the gas station has a fitting that only opens when you put it on the tire valve. So now you have to stick your finger in there somehow to get the air to flow. Just open them up.
Old Feb 28, 2025
51Civic's Avatar
51Civic is an unknown quantity at this point
Re: Moisture in Headlight - WILD SOLUTION!
Surely get new Gaskets , if you can find them .
Old Feb 28, 2025
Colin42's Avatar
This was 23 years ago
bolt-on-bandito
Electrical
32
Jan 15, 2020 03:25 PM
Bruce2
Sep 27, 2015 08:45 PM
General DIY
Sep 25, 2015 08:02 PM
260000milesgoal
Sep 25, 2015 07:41 PM
eebing
Sep 12, 2015 05:35 AM
