headlights
Old Oct 26, 2002
velocity's Avatar
velocity is an unknown quantity at this point
headlights
i just installed new headlights and the left shines much higher off the ground then the right one. i can only see the right light on the street but the other one kind of shines straight up. every thing looks like its installed correct. how can i fix it
Old Oct 26, 2002
ak's Avatar
ak
Retired Mod
ak can only hope to improve
Quote
[hr]Open the hood and look at the braces that run across the tops of the headlights. These would be black painted steel. In each brace is an opening, or hole. Take a light and look down through that hole and you will see a white plastic disk with a hex socket in it. That is the adjuster. You can take the right allen wrench or a screwdriver and stick it through the opening and turn that white hex head. That will raise and lower your beams. I have had to do that every time I change bulbs because they all don't fit the same.So just take a look with a good flashlight on top of the headlight housings and you should find that adjustment screw. [hr]
- Bartkat
[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Old Oct 27, 2002
velocity's Avatar
they both shine the same amount but the left light is pointed higher in the air then the right one those adjusment screews will fix that
Old Oct 29, 2002
ducksause's Avatar
ducksause is an unknown quantity at this point
okay I think i've answered this question before but oh well here you go dude.
I had the same problem with my lamps too.
easiest way to fix it is face the car at a flat wall (at night time helps) turn your beams on now pop the hood get a wrench and as you turn the bolt left or right your light beam will adjust height or your light beam. the bolt for adjustment is located right by the main head light bulb is
good luck
Old Nov 1, 2002
WorldsSlowestEm2's Avatar
I dont think u can do that with aftermarket lights
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
