Trunk release not working
Old Sep 10, 2002
cheesy9999's Avatar
cheesy9999 is an unknown quantity at this point
For some reason that last time I locked my trunk release it got stuck and now I can't unlock it. I have to manually walk over to the trunk and unlock it there. The gas cap release still works. I've tried locking and unlocking it many times but it just doesn't work (and yes, I'm using the regular key...not the valet key). Any suggestions? Should I just take it to the dealer?
(btw, 02 EX coupe)
Old Sep 10, 2002
slammed2k2's Avatar
slammed2k2 is an unknown quantity at this point
Take it to the dealer
that kind of S h I t should be covered, u didnt do ne thing wrong
its supposed to be used....
u used it and it broke, its their problem
Old Sep 10, 2002
2k1civicpty's Avatar
2k1civicpty is an unknown quantity at this point
the same happened to me a couple of months ago, it feels like when you put your key in it doesnt do anything when you turn it, i just kept triying until it worked, but it took about 30 minutes to do it, a couple of days ago i tried to lock it again, and it didnt lock. Im taking it to the dealer next week.
Old Sep 10, 2002
ihaveacivic's Avatar
ihaveacivic is an unknown quantity at this point
i had a bad problem like that.. but mine was the Gas tank cover would not open.. lucky for me i wanted to fill it up at half a tank... i took it back to the dealers and the fixed it.. but they broke my backseat side pannel.. its was cracked in half.. so check you stuff befor you get it back.. cause they wanted to say that they didnt do it.. but the fixed it anyhow.
Old Sep 10, 2002
JohnnyLee's Avatar
7thgen guh chee
That must really suck man.
Old Sep 10, 2002
cheesy9999's Avatar
Do dealers ever have a problem with modded cars? I'm not too worried since so far I just have asthetic mods, and nothing major, but at what point DO they have a problem?
Old Sep 11, 2002
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
Quote
[hr]Originally posted by: ihaveacivic
i had a bad problem like that.. but mine was the Gas tank cover would not open.. lucky for me i wanted to fill it up at half a tank... i took it back to the dealers and the fixed it.. but they broke my backseat side pannel.. its was cracked in half.. so check you stuff befor you get it back.. cause they wanted to say that they didnt do it.. but the fixed it anyhow.[hr]
I had a similar problem. The spring that pops the door open fell out. I had to have a friend push/pry the door open while I pressed the fuel door release. Lucky for me the spring was still trapped in there.
Old Sep 11, 2002
Quote
[hr]
I had a similar problem. The spring that pops the door open fell out. I had to have a friend push/pry the door open while I pressed the fuel door release. Lucky for me the spring was still trapped in there.[hr]
mine was missing a few parts but mainly the cable was broken. so they had to redo the cable run.. and thats how my side pannle in the back seat was cracked.
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
oqjoi
Transmission
May 6, 2015 06:27 PM
ORskier
May 3, 2015 12:54 PM
carhag2000
Apr 25, 2015 01:33 PM
cperez53
Apr 16, 2015 09:31 PM
