Fenders need to be cut to fit 18's!?!?
Old Sep 8, 2002
OsOBooSTeD's Avatar
OsOBaNNeD
My car is lowered 1.4 sportline and i have niche pultecs 18x7.5 on it... well so far ive spend bout 1600 on tires in the past 8 months... my camber is totally screwed up... the rear tires angle in, and causes crazy wear on the inside of the tires... my problem is that i cant get the camber kit cause then the wheels wont clear.... i need to cut the lip. THAT BLOWS .. that lip is thick.. how the hell am i gonna fix this? I ve herd alot of advice from people and i dont like any of their ideas.... everything from ... dre mel, to rolling a baseball bat. I dont trust a body shop to do it .. but at the time time i dont want to F*#* the paint up... what can i do?[IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Sep 9, 2002
importz2k1's Avatar
Who said the wheels cant clear with a camber kit ????
Specially with your drop, it's not drastic! There should be plenty of room to get your camber correct, even with 18's!
I have Neuspeed race 2.25 frt / 2.0 rear drop on 17's and I still have about 1/2 inch clearance!
Do a little more research before you believe the first thing you hear, it will save you alot of headaches in the future !
Hope this helps you man. If not, there are plenty of people that know their stuff on here!!
Good luck!
Old Sep 9, 2002
nytejade's Avatar
nytejade is an unknown quantity at this point
I have a Neuspeed 1.75" drop all around with 18" Primax wheels and 215/40/18 Yokohama Paradas. My right rear tire used to get eaten to hell by my lip until I got an alignment and properly adjusted the camber at the rear wheels. Now, if I go over a drastic bump or I have too many people in the car it'll rub on the top of the tire, but it'll just rub it won't chew anymore. Get a camber kit if you don't have one, and get an alignment, you'll be fine. If you do still rub bring it to a body shop. That lip is very easy to roll.
Old Sep 9, 2002
Erichyung's Avatar
Erichyung is an unknown quantity at this point
chens,
you just need to shave the fenders, it's only 15 bucks per side. It's no biggy, and you won't even be able to tell the difference from outside.
and you should really get it cuz once you have the camber kit your gonna hit the fenders .
Old Sep 10, 2002
1hot01civic's Avatar
1hot01civic is an unknown quantity at this point
I have sportlines too, mine are fine about 1" or less of gap I too have 18's. what size tires do you have? I have 215/35/18 maybe that would make a difference
Old Sep 17, 2002
Erichyung's Avatar
yea it would
Old Sep 17, 2002
nytejade's Avatar
I have 215/40/18. It makes the difference of not rubbing. [IMG]i/expressions/face-icon-small-smile.gif[/IMG]
Old Sep 17, 2002
OsOBooSTeD's Avatar
OsOBaNNeD
THATS THE STUPIDEST THING IVE EVER HERD .... 215/35/18'S ARE SMALLER THEN 214/40/18 WTF??
Old Sep 17, 2002
OsOBooSTeD's Avatar
OsOBaNNeD
And u guys are Lame ... THAT LIP IS THICK and i dont want my paint to chip.... NOT TO MENTION I HAVE ABOUT 400 LBS of stereo back there.. IT SITS LOW. DAMN U GUYS ARE EGO DRIVEN..... STOP , LOOK AT THE POST AND REPLY WITH SOME THOUGHT. THANKS .[IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Sep 18, 2002
nytejade's Avatar
Quote
[hr]Originally posted by: Chenz
And u guys are Lame ... THAT LIP IS THICK and i dont want my paint to chip.... NOT TO MENTION I HAVE ABOUT 400 LBS of stereo back there.. IT SITS LOW. DAMN U GUYS ARE EGO DRIVEN..... STOP , LOOK AT THE POST AND REPLY WITH SOME THOUGHT. THANKS .[IMG]i/expressions/face-icon-small-mad.gif[/IMG][hr]
What the hell are you talking about? Yes 215/35/18 is smaller than 215/40/18. 215/35 shouldn't rub. If it does, bend that lip. If you're a little girl and you can't do it yourself ( hey, i couldn't either ) then bring it to a body shop. No big deal man, relax. You don't have 400LBS of stereo equipment back there either. Relax, figure out a solution. You're just going to break stuff if you get angry.
juror
Suspension DIY
Jul 30, 2019 03:28 AM
beeemerdude
Jul 23, 2015 03:53 PM
EM_WON
Jul 22, 2015 06:49 PM
suburbanite
Jul 17, 2015 03:05 PM
stvpagn
Jul 9, 2015 09:59 PM
