My Steering Wheel Shakes!
Old Aug 20, 2002
TwistedCivic's Avatar
TwistedCivic is an unknown quantity at this point
When I drive over 60 MILES/HOUR my steering wheel shakes, it increases as I speed up, is my alignment off?[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
Old Aug 20, 2002
mohawkboom's Avatar
Your tires are improperly balanced...
Old Aug 20, 2002
thax man.
Also the tread on my front tires wears off hella quick, my back tires looks brand new, I know it is front wheel drive, but It never wore down this quick, now they look like radial tires.... can you guys suggest anything?
Old Aug 20, 2002
solar's Avatar
solar is an unknown quantity at this point
Alginment won't cause a vibration but will wear out tires prematurely, unless of course you drive hard into turns and don't rotate your tires. If you don't have them rotated and balanced regularly you'll have the problem you discribe, but if you burn it hard into turns and drive hard your tires will wear quickly on the outsides. BTW all tires on new cars are Radials, Bias Plys are very hard to find, unless you have a Semi truck you won't find them. How many miles do you have on the car?
Old Aug 20, 2002
130, 000 miles 94 civic. I do rotate my tires As I should, and I rarely turn hard. But I think my alignment is off....[IMG]i/expressions/face-icon-small-mad.gif[/IMG]
Old Aug 20, 2002
solar's Avatar
If your tires are rotated regularly and your front tires are wore out and the rears are fine you must have a bad alignment problem.
Old Aug 20, 2002
2Hottie's Avatar
2Hottie is an unknown quantity at this point
Have the same problem....trust me, if you take it to get balanced and they do it right, it will make a hella difference!!! I just found out that if you get your tires balanced @ National Tire & Battery, they will give you freee balancing for the life of the tires....cool huh???
2Hottie
Old Aug 20, 2002
Thanx alot for the help guyz, I owe you one...
Old Aug 21, 2002
2Hottie's Avatar
Does anyone know how tight hub rings are supposed to fit??? I mean, do they hav eto be so tight that they snap right inside the wheel hub and have to be pulled out or loose enuff for them to pop out of the wheel hub themselves??
2Hottie
GotSiR
Jun 23, 2016 04:06 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
kaashifv
Interior
Jul 27, 2015 05:28 PM
breanna_17
Jul 21, 2015 04:01 PM
qlitten
Jul 21, 2015 03:12 PM
