problems with first gear and reverse
Old Jul 31, 2002
Les's Avatar
Les
Les is an unknown quantity at this point
This is my first stick so I don't know if this is normal and I bought the car a year old so I don't know how it drove new. It seems like it's always hard to get it into reverse and I usually have to put it in another gear before it'll go in reverse and it makes a loud noise when I back up. Also, sometimes I can't get the car in first. It feels like something's blocking it, it won't even go partially in. Sometimes I'll fight with it and it'll go in most of the time when it happens have to start in 2nd. Don't really know what to look for, could use any info on this and what to keep a eye on with a manual.
Old Jul 31, 2002
nrrhgreg's Avatar
nrrhgreg is an unknown quantity at this point
If you're trying to downshift into 1st, then yeah, you're going to have a little resistance. But if you're sitting still trying to get it into 1st, then something is wrong. Reverse can be difficult to get into sometimes, just takes practice.
Old Aug 1, 2002
n00dleboy's Avatar
n00dleboy is an unknown quantity at this point
Reverse also doesn't have a syncro, so sometimes you'll have to let it roll a bit and let it slide into gear.
Old Aug 2, 2002
WD40's Avatar
WD40 is an unknown quantity at this point
My 6th gen developed the 1st gear blockage problem after years of abuse. I had to put it in 2nd, and then slide into 1st. I think if I were you I'd take it to your dealership and have them check it out just to make sure everything's ok.
Old Aug 2, 2002
Guy01's Avatar
Guy01 is an unknown quantity at this point
you are not supposed to reverse while moving otherwise you will grind your gears. so make sure ur car is still before u shift into reverse. im not sure if thats what u did...maybe i misunderstood what u said. for me, its tough to move into reverse sometimes also. as for the first gear problem that you're having...there should be resistance around 7-8mph.
Old Aug 8, 2002
scsGrumPyDriveR's Avatar
scsGrumPyDriveR is an unknown quantity at this point
HEY LES...
I"M having the exact problem as u did. I posted it up before but i guess not alot of people noticed.
The problem with not getting into first is because there is a thing that prevents u to downshift to first. Your car has to be slow enough or stopped in order to put it in first. It's a good thing
And the other problem I had is not being ablee to get into first at all even when i'm stopped.
I have no idea why, but that problem only happens like once every few months =)
Old Aug 11, 2002
jazzmans's Avatar
jazzmans is an unknown quantity at this point
If you're having problems getting it into reverse, then with the clutch in put the tranny in 1st, then without releaseing the clutch, pull it out and it should go directly into reverse, they're linked. If a problem in 1st, let off the brake and let the car roll an inch or so, that should fix the problem.
FWIW I've not had any difficulties with the tranny in my 02 lx sedan, It is so far a fabulous transmission. (I've only got 4k on the car so far)
jaz
Old Aug 12, 2002
Chris2k1civic's Avatar
Super Member
Chris2k1civic is an unknown quantity at this point
yeah i have that problem too but i dont downshift into 1st... its when i take off.. im not sure about that either.. and my reverse does the same thing.. humm[IMG]i/expressions/face-icon-small-confused.gif[/IMG] im thinking of taking mine to honda and see wat they say..
Old Aug 12, 2002
Chris2k1civic --. they're going to say NOTHING"s WRONG!.
Old Aug 12, 2002
Super Member
ehh its worth a try..
Blazz
Jun 4, 2015 01:04 AM
cruisers10
May 12, 2015 10:46 PM
CiViCPrAnInG2k1
Jan 2, 2002 06:57 AM
02Si
Dec 14, 2001 10:26 AM
Russps
Nov 8, 2001 02:00 AM
