AC sounds like a Turbo
Old Jul 26, 2002
MoeMagic's Avatar
MoeMagic is an unknown quantity at this point
[IMG]i/expressions/face-icon-small-disgusted.gif[/IMG]
2002 Civic Coupe LX
I notice when I run the AC and accelerate, the AC compressor whines up like it's a turbo. It will do this between 2000 and 5000 rpm and in the first three gears. Once I get it into 4th, the sound is gone, probably by then I'm not taxing the engine much.
It's weird. I hit the gas and the AC whines up. Drop the gas to go into the next gear and it whines down and back up again in the next gear. Once in a while I'll get it just at the right vibration and the noise is no longer a whine but like a truck using its Jake brake.
I know its originating from the AC as I have shut it down while accelerating and the whine instantly quit.
Anyone else with a similar tale.
Thanks in advance.
MoeMagic
Old Jul 27, 2002
solar's Avatar
solar is an unknown quantity at this point
Take it from me, I'm a old A/C tech, don't run your A/C anymore!!! Sounds like you have a A/C compressor going bad, take it back to the dealer ASAP. If you keep running the A/C compressor the way it is right now; with the sound your describing, you might blow the compressor "reed valves" and damage the rest of the system. By running broken pieces of damaged valve bits though the system you'll have many more problems. Even if its under warrenty I'd try to save as much of the system as you can.
If you want more info on A/C systems you can PM me.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
CraigW
Aug 18, 2015 07:06 AM
BootyDo
Jul 26, 2015 10:38 AM
ShaneShepley
Bolt-on Engine Performance
Jul 21, 2015 05:25 AM
Theshwartz35
Jul 18, 2015 10:49 PM
