2002 LX 5 speed manual problem
I have a 2002 LX 5 speed and i just recently gotten a problem with my tranny. The shifter doesn't move as smooth in neutral anymore and sometimes it gets stuck. Also when i try to shift into reverse, its so hard to. I have to put so much force to shift into reverse. I have no idea whats wrong, anyone have any ideas?
thanks in advance
-WiLL
thanks in advance
-WiLL
OMG i thought i was the only person who had the same problem, no matter how far i push the clutch in i have to slam it into reverse, i have same year and all as yours just a black. I taking ti to honda let them figure the **** thats why i bought it brand new.[IMG]i/expressions/face-icon-small-wink.gif[/IMG]
Yea. Thats happened to me a couple times. Just put your car in Neutral, leave it there for a few seconds or so, then trying throwing it into Reverse again. Don't do it fast or anything, just do it at a moderate speed. Thats what I do. My freind has the same problem with his Cavalier. What he does is put it in first, then second, then goes over to reverse...weird...but it seems to work [IMG]i/expressions/face-icon-small-smile.gif[/IMG] hehehehe.
man that sounds like it sucks to it every time you have to go into reverse. ive got a 01 civic wit a 5 speed and mine is fine never had no problem like that. hope you can get it fixed
This is part of the bushing problem which is well covered in this forum.
Take your car to Honda there is a TSB that covers the issue.
Please do a search for car comming poping out of second gear or problem / trouble shifting from 1 to 2 secon gear etc....
Quote
[hr]Originally posted by: mattskav
Please do a search for car comming poping out of second gear or problem / trouble shifting from 1 to 2 secon gear etc....[hr]
If it seems like the shifter won't go into reverse on the first try, do NOT try to slam it in ! Push it back into neutral and pump the clutch once or twice, and then try shifting again... that should always work.
Quote
[hr]Originally posted by: Ronin
But they're not talking about 2nd gear problems. They're talking about problems with shifting into reverse, which is very common on all 5-speed cars, not just ours. I had a 91 Corolla SR5 with the exact same shifting into reverse problem. And believe me, the clutch and shifter on that car was way inferior to what I have now.
If it seems like the shifter won't go into reverse on the first try, do NOT try to slam it in ! Push it back into neutral and pump the clutch once or twice, and then try shifting again... that should always work.[hr]
Quote
you should take it to honda and get the fix, go from there...
CarStuff
Dec 6, 2020 12:52 PM
Civic2002lx
Oct 7, 2015 09:17 AM
izdman
May 19, 2015 03:43 PM
jakeconnor
May 5, 2015 07:30 AM
CapYoda
Nov 11, 2001 05:17 PM
