Rear deck rattle
Old Jul 9, 2002
2001Si's Avatar
2001Si is an unknown quantity at this point
Rear deck rattle
I have taken my CDM 2001 Si (USDM EX) into Honda twice for this rattle and have given up. There is a rattle in the rear speaker deck at low RPM. They say it has something to do with the third brake light, and have replaced it under warranty, although it is actually worse now >:-| Any help??
Old Jul 9, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
I posted a service bulletin for this. Do a search for "rear deck" to find it.
Old Jul 10, 2002
FroggerDude's Avatar
FroggerDude is an unknown quantity at this point
it is the rear brake light. when i turn up my music it rattles. so i opened my trunk and stuck my fingers in some of those spots. found out that when i press the plastic piece of the rear brake light it stops rattling. so i stuck a piece of cloth rolled up so its big enough to push it up a little. hasn't rattled since.
if u do it, i recommed unplugging the power plug to the rear brake light. its right in front of the hole. gives you more room to push the cloth in.
Old Jul 10, 2002
neoretromax's Avatar
neoretromax is an unknown quantity at this point
well if honda cant fix it you can do it yourself if you're up to it. here's a diy to take off the rear deck.
rear deck removal
Old Jul 12, 2002
FiresVTEC's Avatar
FiresVTEC is an unknown quantity at this point
i have had the same problem and its been happening for over a year now, i just havent had time or the motivation to bring it in. it happens either when the speakers hit hard or even if the radio is off and i rev the engine. ill bring it in eventually, i just have to get off my lazy @ss.
Old Jul 13, 2002
Purple2001Civic's Avatar
Purple2001Civic is an unknown quantity at this point
well mine is rattling too i just ignore it and hope i can find some gasket that wont look that bad in between the rear deck and the window
Old Jul 14, 2002
Jeff's Avatar
Jeff is an unknown quantity at this point
Do what i did, I work for a computer company so I get all sorts of motherboard boxes. Take the foam pads and shove it between the 3rd break light and the rear dash. worked for me. =)
Old Jul 16, 2002
2001Si's Avatar
I tried sticking some pads between the plasting and the window - it doesn't work, the plastic isn't rattling against the window. Don't bother, mine left some stick s*** on the plastic that was hard to get off.
Old Jul 16, 2002
its not between the plastic and the window 2001si. its in the trunk. underneath the brake light. its plastic rattling against plastic. so if u stuff something in there to push it up a bit. it won't rattle anymore.
Old Jul 17, 2002
Ronin's Avatar
Quote
[hr]Originally posted by: Purple2001Civic
well mine is rattling too i just ignore it and hope i can find some gasket that wont look that bad in between the rear deck and the window[hr]
That's what I used to do, but it looks really ghetto no matter what you use. I finally fixed it completely by shoving rags into all the openings underneath the rear deck, from the trunk area. My dealer used a service bulletin on it, but they did not fix it completely.
oddtodd
Detailing
Aug 23, 2015 03:03 PM
loosescrew84
16
Aug 11, 2015 07:08 PM
frisbeeguy2
Jul 30, 2015 03:00 PM
Yazan93
Jul 14, 2015 08:56 PM
