RPMs drop WAY low
Old Jul 5, 2002
Freshguju's Avatar
Freshguju is an unknown quantity at this point
RPMs drop WAY low
i put in some underdrive pulleys and my RPMs drop way low i mean like to the lil line where anything under it the car is shut off... well i could be driving around put my clutch in to make a turn and my car would DROP in RPMs like it was going to turn off... i dont know if it could be from my pulleys or im draining my batt. wit my amp.... does anyone eles have this problem????
What should i buy next.. hmmmm
Old Jul 5, 2002
Ronin's Avatar
Ronin is an unknown quantity at this point
Did you have this problem before installing your pulleys?
Old Jul 5, 2002
Mbow's Avatar
How long has it been since you installed them? Did this happen immediatly after installation on some time after? The ecu needs time to adjust to the new pulleys.
Old Jul 5, 2002
Freshguju's Avatar
its been about 6 months since i put thos pulleys in.... its the problem i have been reading alot about from other members... the RPMs srop and shoot up back to norm. some say it might be that i have a bad spark plug....what kinda plugs should i get?
bit the be the
Old Jul 5, 2002
spoiledsteph
Guest
Posts: n/a
mine idles low too.....it scares me cuz i think that my car is gonna shut off. i engage the clutch and rev it up a bit, and it seems to help. but is there a solution? my car has never stalled...and i just noticed this after i came back from teh dealer after my 10k check.....
Old Jul 5, 2002
mohawkboom's Avatar
Mine does that because of the strain on my engine from ym H/O Alternator...does it Idle a little low..but not bad..and drop drastically when you depress the clutch?
Old Jul 5, 2002
spoiledsteph
Guest
Posts: n/a
for me, when the clutch is engaged, the rpms go to around 0 or something.....but when i sit at a light or in traffic, it idles at like 500.....really low, when it usually idles at like 750-800. i guess i have to pay more attention to what rpm it is at when the clutch is in.......
whats an H/O alternator?
Old Jul 6, 2002
Ronin's Avatar
Quote
[hr]Originally posted by: Freshguju
its been about 6 months since i put thos pulleys in.... its the problem i have been reading alot about from other members... the RPMs srop and shoot up back to norm. some say it might be that i have a bad spark plug....what kinda plugs should i get?[hr]
Ok, but did it start idling funny immediately after the pulley install 6 months ago, or way after that? If it was right after, then it's likely the problem is caused by your pulleys.
Old Jul 6, 2002
Freshguju's Avatar
its been happening since about my 10k, but after i got my pulleys is the first time it has turned off while i was in the middle of a 4-way stop... i also have a big amp with the stock batt... does anyone know if using v-tech alot is bad? i got almost 21k...
i need that K20 swap to be done
Old Jul 6, 2002
RockfordFosgateBwoy's Avatar
RockfordFosgateBwoy is an unknown quantity at this point
Quote
i need that K20 swap to be done[hr]
im just gonna control myself and not flame you becuase once upon a time we were all clueless....
ITS VTEC! v-tech phonnes do suck and i would not recommend using them alot. VTEC is just a cam lobe that allows more air into the engine at higher RPM's, nuttin bad about it!
RF Bwoy
Old Jul 6, 2002
Freshguju's Avatar
hey im not that clueless i just never owned a honda before... never had vtec, only thing i have that comes close to like vtec was my quad-cam LEXUS engine
Cajunkev1
Apr 3, 2017 04:32 PM
thana
Jun 15, 2015 11:58 PM
The Big Dutch
Jun 9, 2015 07:49 PM
Wild Cranker
May 19, 2015 06:10 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
