03 EX does not start
Re: What can you swap on a 01 Civic Ex to a 04 Civic ES
have a 2003 Civic ex. Pulled out of the driveway and it just cut off. Would not restart. Here is a list of repairs I have made in order.
Fuel pump
fuel regulartor
sock filter
air flow sensor
altenator
plugs(old plugs were sooty and after replacing the new plugs soon looked the same) Air/fuel ratio???
cam sensor
timing belt,water pump
Still no start until I replaced the entire fuel pump assembly. Then I got it started but it idles rough and when I press gas peddle it does not accelerate. Plugs still look sooty.
I got a o2 sensor code on both up and down stream sensors. These have never been replaced(236k) so I cleaned both(soaked in gas for 2 days) of them and it made no difference.
Nothing on the throttle body sensorwise has been replaced.
I cleaned the injectors and they worked fine.
replaced both cam and crank shaft O ring seals.It was leaking oil on the crank seal very badly and the crank sensor and the bottom around the shaft was covered in grim and dirt including the crank sensor. Both upper and lower covers had holes worn in them were road crap was getting in there. Reason for the build up of crap.
This car never smoked or burned oiland ran fine until this happened.
When I took out the fuel rail to clean injectors it had a damper/pulsator on the fuel rail. I took that apart.It had a screw holding the damper together. When I put it back together not sure if I reset the screw to where it was. I heard that the dampers are pre-set at the factory and should be left alone.
Not sure where to go next???
Any advice or direction would be greatly appreciated. Would love to get a few more miles out of it because of all the $$ I have put into it. If not I will sell for parts.
Thanks
Fuel pump
fuel regulartor
sock filter
air flow sensor
altenator
cam sensor
Thanks
Re: 03 EX does not start
moved out of the unrelated thread.
There's a "New thread" button on the top of each section.
PS: Have you diagnosed before starting to swap parts?
Lanegarrett73
Mar 13, 2018 07:23 AM
CraigDillon
Jun 30, 2017 09:14 AM
guitard00d
Mar 1, 2015 12:28 PM
