loud humming noise when idiling and gets louder when accelerating
it’s coming from like under the air box on top of the transmission i doubt its the transmission but it sounds like a vacuum leak my car has 142k miles and it’s automatic
Re: loud humming noise when idiling and gets louder when accelerating
Never read the sound of a vacuum leak being described as a humm but it’s your ears.
Honda Civic has no vacuum lines in that area, but suppose a failed egr gasket or intake crack might seeming sound like it’s comming from tranny area.
You can leave the air filter box alone and just pull off the resonator box that’s right on top of the transmission. to have a better “ear” to your problem.
I usually suspect a failed bearing when I hear a humm around things that rotate. Mechanic stethoscope or metal rod pressed to the outside of your ear canal moving from spot to spot in the area usually locates it.
For a audible hiss aka vacuum leak I use a meter long length of hollow tubing to isolate sound sources.
chrisdesmarais
Sep 28, 2013 10:06 PM
LYC7
Jan 10, 2012 05:54 PM
