Mysterious rattle noise tried everything
Old 08-25-2018
7thgenexca's Avatar
7thgenexca is an unknown quantity at this point
Hey so i got a 2002 honda civic si ( ex in america i assume ) getting a weird metal on metal rattle sound extremely loud and embarrassing lol sounds like its coming from the headers really hard to tell though mostly happens on deceleration
things ive tried :
replaced donut gasket ( previous one looked toast )
replaced spring bolt kit ( really sounds like this is the issue)
added washers to springs on bolt kit to try and tighten the spring up a bit incase that was the issue 1 to 4 washers didnt help seems maybe to have quieted down though.. suspecting the spring isnt strong enough on the kit i bought maybe might try a dealership
removed all heat shields
car has been on 3 5 hour plus trips in the past month it really seems to do it during inclines on hills and around 2500 to 3500 rpms, does not do it on highways as far as i have noticed does it in all gears and neutral have a hard time replicating the noise when trying to show it to people seems as if when parked its hard to make it do it and seems to slightly do it if you pull the throttle body and rev to 3500 then let go, completely stumped been at this preiodicaly looking at it for weeks i really have no other idea
also no it isnt the cat or o2 sensors o2 sensors are tight and its running a test pipe
all ive found on google so far is possibly the fuel grade but i doubt that.
no mods done to it bone stock beyond cat delete
Old 08-25-2018
Re: Mysterious rattle noise tried everything
I can't hear anything. (hint)
Old 08-25-2018
Slumpertcivic's Avatar
Metal on metal sound very nondescript , does it sound more like a buzz, a ping, or like a sledgehammer hitting railroad tracks...
Old 08-25-2018
7thgenexca's Avatar
buzz but sorta pingy, i just was looking at the exhaust diagram and found a heat shield i missed ill post part number below went under neath found it rotted away from 1 bolt and semed to be sitting on my shifter cables which come to think of it have had some weird noised coming through my shifter occasionally, anyways took that off but not leaving for a few hours and was in between doing things when i saw the diagram hopefully that was the source of the rattle will know later
74252-S5A-000
Old 08-25-2018
7thgenexca's Avatar
Noise is still there
Old 08-25-2018
We still cant hear anything (HINT)
Old 08-25-2018
7thgenexca's Avatar
PROBLEM SOLVED!!!
boredom got the best of me so i took the whole exhaust off the car from the manifold, looks like its doublle walled or something because it cracked on the inside of the exhaust right where it bolts to the manifold i took my o2 sensor out and stuck my welder down the down pipe and welded the crack up and put her back up and its gone so if anybody has a buzz up front on a 01 to 05 ex or si coupe that is your issue friends
Old 08-25-2018
Still no video so we all can hear it?
mscott827
03-17-2013 03:33 PM
avious
12-02-2011 06:28 AM
Maple50175
07-19-2007 03:51 PM
hypnotic7thgen
03-14-2003 08:12 PM
Litespeed
12-05-2002 08:11 PM
Quick Reply: Mysterious rattle noise tried everything
