Bent Washers on Spark Plugs?
Old Jul 18, 2018
tbroyles94's Avatar
tbroyles94 is an unknown quantity at this point
Hi, I'm new to the world of car ownership and fixing, but I successfully changed out my spark plugs (yay me) after my check engine light came on, with codes saying cylinders 2, 3, and 4 misfired. I have a 2002 Honda Civic EX. My question is that the washer/gasket/sealer bits of the spark plugs I took out from the 3 misfired cylinders were bent and stuck some length up the threads. I just wanted to check here to see if that is a an issue caused by something else that will reoccur on my new spark plugs, or just a coincidence from me taking them out? What causes bent gaskets?
This is a sharable link from my Google Drive to show a photo of what I mean. I couldn't get it to attach normally to the post, so I had to improvise...
https://drive.google.com/open?id=1Az...NBahaEK2BK4ilM
Thanks for your help!
Old Jul 18, 2018
GolNat's Avatar
Prelude Owner
Re: Bent Washers on Spark Plugs?
I think they are supposed to be bent or cupped to create a downward pressure. As you loosened the plug the washer probably just worked it’s way down.
What plugs did you put in? Iridium?
Old Jul 18, 2018
BrotatoChip's Avatar
Super Moderator
The EGR runners are known to clog causing misfires as well. This happened on my civic a few years back, probably around 200k-225k miles.
Old Jul 18, 2018
tbroyles94's Avatar
I put in double platinum. I think it was Bosch 8112.
What are EGR runners?
Old Jul 18, 2018
Slumpertcivic's Avatar
Those plugs look fine, certainly not junked up enough to cause misfire issues.
Old Jul 18, 2018
Colin42's Avatar
throw out the bosh and buy the correct NGKs
NGK 3271 {#PZFR6F11}
the passages in the intake manifold that the egr system uses
Old Jul 18, 2018
GolNat's Avatar
Prelude Owner
Those are not the correct plugs. The ones you took out did not look correct either. Yes they are NGK but the tip looks like a resistor style plug.
Get NGK Iridium plugs and throw those Bosch in the trash.
Old Jul 18, 2018
tbroyles94's Avatar
Whats wrong with Bosch? Both the auto parts store and a website (rocket auto or something? Don't remember) said those would fit my car. I was fairly certain the ones I took out were the manufacturer recommended NGK ones, the code stamped on the side is the same.
Old Jul 18, 2018
GolNat's Avatar
Prelude Owner
Yes they fit but they are not the correct parts. Sometimes it will throw a code other times it won’t but they won’t last long. That’s my issue with parts stores and websites. They also say universal O2 sensors fit. Yes it fits in the hole but other then that they won’t work.
The plugs you pulled out match the number posted? Usually iridium plugs have small electrodes not the older flat style. This could be the cause of the mis fires. Iridium plugs are good for 100k miles.
Old Jul 18, 2018
tbroyles94's Avatar
So basically I'm fine to leave them in for now? It won't damage the car, it just won't last long? Because as a recent college grad, I have little money and no desire to throw away $20 if I don't have to for a few months.
Old Jul 18, 2018
GolNat's Avatar
Prelude Owner
You should be fine as long as you have no CEL.
Usually people buy the non iridium plugs because they are half the price.
Old Jul 19, 2018
The plugs he pulled out were standard. (# starts with Z not P or I)
The last installer went cheap, but that doesn't look like a problem so far.
2002blackcivic
Oct 1, 2006 09:42 AM
iamboo
15
Nov 1, 2004 11:53 AM
booba5185
Jul 7, 2004 12:15 PM
Al_ics
Vancouver
May 16, 2004 09:25 PM
MikeyBoy
Jan 26, 2002 06:45 AM
