2004 Honda Civic ex check engine light
Old Jun 7, 2018
Tdubs613's Avatar
Tdubs613 is an unknown quantity at this point
Hey so I have a 2004 Honda Civic ex coupe I was on the way back from Florida when my check engine light came on I waitited till i got home to go to my local autozone to have the code read. It came back as P2646 which is the variable valve timing oil pressure switch. So I changed the part. Drives a little better but still have the check engine light and it now won’t go past 4000 rpms any help?
Old Jun 7, 2018
Slumpertcivic's Avatar
Re: 2004 Honda Civic ex check engine light
Did you check your oil level?
Your car won’t go past 4K as long as the computer thinks you don’t have enough oil pressure.
Old Jun 8, 2018
Tdubs613's Avatar
I checked the oil level and put some in to top it off and now it’s not going past 5000 just buckles
Old Jun 8, 2018
You said it happened on a road trip which if the engine is burning oil would possible drop low enough to cause air to start getting sucked in and trigger the code even though the oil pressure idiot light was not triggering yet.
Along same lines it’s possible your oil filter is totally clogged up and the bypass mode is not letting enough oil through for the vtech monitor.
So given a fresh oil change with filter and a drive cycle or code reset if it doesn’t improve then your look8ng at pulling off some parts for cleaning and testing.
Tdubs613
Aug 7, 2018 11:01 AM
mlandmann
Apr 25, 2013 03:11 AM
kor3anmix1
Jul 2, 2010 08:24 AM
lunakim
Mar 13, 2010 04:03 PM
mrb420
19
Oct 31, 2006 08:46 PM
