'03 Honda civic starts then shuts off
So, my check engine light had come on while i was driving my Civic on Friday and I didn't think too much of it until I turned a corner 15 minutes later and my car shut off. When I tried to restart my car, it would start for about 3 seconds and immediately shut back off. The accelerated doesn't rev the engine at all. I used an OBD2 scanner and it was a code P0361 I believe, and said something about the camshaft position sensor. So, thinking that was the problem, I changed the sensor and it didn't fix anything. At all. It does the same exact thing, starts then goes silent. I sent my car to a mechanic but so far they aren't sure what's wrong with it yet either. Do any of you have any ideas? I'm getting more anxious the more I wait to hear back about my car. I'm a college student and it's my only way around.
Re: '03 Honda civic starts then shuts off
not a diy, not an 8th gen...
moved.
If the mechanic can't figure it out you may need a new mechanic. Is the engine still timed properly?
moved.
Is that a CNG (GX) car? LX? EX? SI? Which engine is in it?
What's the actual code number? (P0361 is not in the list of codes for that year car)
Is the cam timing incorrect?
if it will run more than 2 seconds with the cam sensor unplugged, DO NOT RUN IT...It's probably jumped time or broke the tensioner spring.
Bryce007
Dec 6, 2017 10:07 PM
Bobbyk
Dec 24, 2014 12:59 AM
sarcastasaur
May 17, 2014 09:06 AM
tempid
Dec 26, 2012 08:38 AM
presence
31
Oct 11, 2012 08:33 AM
