Help!!! Asap!
Old Mar 31, 2018
mhammond1127's Avatar
mhammond1127 is an unknown quantity at this point
Help!!! Asap!
Ok so recently I replaced my thermostat and radiator. I literally replaced it last weekend. Did an oil change and spark plug replacement too. But tonight I drove about 20 minutes to a gas station and when I pulled up my heater wasn’t blowing hot it was blowing cold. (Tall tale sign it’s probably low of coolant) so I let the car set with the hood up and cool off. I popped the radiator cap, made a pop sound, basically letting me know it’s at least sealing. It’s not leaking on the ground from what I’ve been seeing. I check it all the time (I’m paranoid about the radiator lol.) Well I squeezed the hoses and low and behold it wasn’t full, the reservoir was, but right in front of the radiator and reservoir is my air intake resonator, and around the rim of it you can see coolant pooled up but I don’t know if it’s coming from that or if it’s leaking it and blowing it on top of it. I’m home and letting it cool before I start digging into it further. I’m going to take my reservoir off and empty it and clean the little hose attached to it to see if maybe it’s clogged. I’ve never burped the system I don’t even know how to do that. SOMEBODY PLEASE HELP ME!!!
Old Mar 31, 2018
Re: Help!!! Asap!
Head gasket blown
NEXT!
Old Mar 31, 2018
Re: Help!!! Asap!
See first post in this thread:
https://www.civicforums.com/forums/3...reference.html
Old Mar 31, 2018
Re: Help!!! Asap!
Originally Posted by ezone
Head gasket blown
NEXT!
But here’s the catch. This what I’m confused by, it’s on the left side of it and you can see splatter marks on the top of the resonator which looks like it’s being blown onto it. It’s closer to the passenger side and battery.
Old Mar 31, 2018
Re: Help!!! Asap!
See previous post
Old Apr 1, 2018
Slumpertcivic's Avatar
Re: Help!!! Asap!
Originally Posted by mhammond1127
Ok so recently I replaced my thermostat and radiator,
So out of the blue you just decided to replace those two items or you already have been having a over heating issue?
Not sure why you seem to be thinking a overfilling overflow tank would leak out the bottom.. it’s gonna come out at the top.
If you don’t believe us, you could unplug your overflow tube at the rad and connect a 15 foot hose from Home Depot and run the other line into your cabin into a empty gallon bucket. Prolly won’t have to drive far till that bucket gets 1/2 filled.
Old Apr 1, 2018
pjweber's Avatar
pjweber is an unknown quantity at this point
Re: Help!!! Asap!
Head gasket blown
NEXT!
Yep! Agree. Just use Honda parts when you fix it, don't try to find the cheapest parts on Ebay or Amazon.
Old Apr 1, 2018
pjweber's Avatar
Re: Help!!! Asap!
Because it is being pushed out of the reservoir cap spraying around the battery and resonator area.
Old Apr 1, 2018
Re: Help!!! Asap!
closing thread for OP is not listening
arubio0812
Jul 19, 2011 05:43 AM
peimp
Aug 2, 2005 09:31 AM
silverem2
May 17, 2004 02:25 AM
joescivic02
Apr 14, 2004 01:39 PM
