Long cranking time when warm
Old Mar 5, 2018
panama's Avatar
panama is an unknown quantity at this point
My 2002 1.7L will start when it's cold very quickly every time but once it warms up the crank time goes way up. The other day I thought it was taking so long it wasn't going to start. I even called my son to pick me up. Waited a minute or so, tried starting it and it started. The only thing I tried was replacing the fuel pump relay located behind the glove box.
Old Mar 5, 2018
Colin42's Avatar
Re: Long cranking time when warm
one of the coolant temp sensors may be giving a wrong value when warm, causing the computer to provide the wrong air/fuel mixture and making the car hard to start.
If you can plug in a scanner that shows live data it will show you all the sensor readings and you can see if one is out of whack
Old Mar 5, 2018
Check engine light on? Got fault codes?
Old Mar 6, 2018
panama's Avatar
The check engine light is not on. Would I still get error codes if the check engine light isn't on?
Old Mar 6, 2018
Colin42's Avatar
the bulb may be burned out, or someone may have removed it
Old Mar 6, 2018
panama's Avatar
The check engine light comes on when I first turn the key, the engine starts and the light goes off.
Old Mar 6, 2018
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
Aren't there 2 main fuel relays for our vehicles? If so, replace both. They are behind the glove box.
Old Mar 6, 2018
You can find if something useful is stored in memory
2 mains; one is for the fuel pump and other is for PCM
Old Mar 6, 2018
panama's Avatar
According to the Chilton manual I got from the library there are two relays called PGM-F1 and the fuel pump relay which I already replaced. These are behind the glove box. Should I replace the PGM-F1 relays?
Old Mar 6, 2018
It's PGM-FI, not F1 (letter I, not number one)
As I said earlier, one main relay is for the fuel pump and the other main relay is for the PCM. Both should have originally been blue.
You can replace it if you wish
How many relays does your car have behind the glovebox anyway?
3rd relay (black) is for reverse lights on auto trans cars
Personally, I'd want to connect a good scanner so I can watch (or record) live engine operating data when it acts up.
Old Mar 7, 2018
Slumpertcivic's Avatar
I am courious as too what made you think you should just up and replace the fuel pump relay.
Logically if the car will start at all and once started stays running normally even under load then it’s not a fuel supply issue.
So why did you start there?
Old Mar 7, 2018
mikey1's Avatar
sometimes caused by a poor ground......
start by removing and cleaning your battery terminals,
make sure they are clean and tight
Old Mar 7, 2018
panama's Avatar
Answer: 3 left to right a black one following two side by side blue and to the right of it a brown one.
fuel pump fuel pump
relay.
Answer: I read a post on another forum site and that was what was recommended. I guess I wasted $25.
woodsjd1
Jan 12, 2014 08:38 PM
moe2o4
Mar 18, 2012 09:24 PM
mugenman
May 27, 2007 10:21 AM
someguy
Sep 29, 2004 04:36 PM
FALKEN
Sep 10, 2004 09:44 AM
