How to tighten up the compression test fitting?
Old Jan 28, 2018
Craig Seybert's Avatar
Craig Seybert is an unknown quantity at this point
Hello all. I am performing a compression test on my 05 civic. I cannot get a socket down into the spark plug hole to tighten it up. i tried to tighten it up as much as I can with the compression testing hose, but after slight resistance, the hose just swivels. and when I turn the engine over, all the air leaks out of the socket hole. any ideas?
Old Jan 28, 2018
Re: How to tighten up the compression test fitting?
i should mention, the socket i used to get the plugs OUT, is too small to snug up the compression tester socket
Old Jan 28, 2018
All my spark plugs look like #10 in this image.
https://www.carid.com/images/autolit...on-fouling.jpg
Old Jan 28, 2018
Remove compression tester hose and throw it away !
Buy a fresh set of plugs and install. Drive it until the plugs look ugly again.
(Depending on how many miles it took to foul those plugs, I might just install standard NGK plugs, not platinum)
It's an oil burner? Remember to check and add oil on a regular basis.
What was the question again?
Old Jan 28, 2018
Thanks for the reply. It is an oil burner, big time. about a quart every 2000 miles. plugs and cat are fouled because of it, I was trying to do a compression test to determine if it was the rings or valves. but i can tighten the compression tool to the engine block, air seeps out immediately after engine stops turning.
Old Jan 28, 2018
Throw away the tester hose before you get it stuck and can't get it out (THAT'S gonna ruin your day for sure)
Buy or rent another if you need to.
A compression test will never tell you the condition of the (stuck) oil control rings.
The oil rings could be missing completely and you'd never see it in a compression test, because the 2 compression rings are still doing their job.
One quart in 2k isn't huge (I know it eventually takes its toll though), unless nobody remembers to check and add when needed. Some engines I deal with consume oil much faster than that.
I'd guess it's stuck rings just because it's very common, but if you're gonna pull the head, plan on doing both stem seals and piston rings.
Old Jan 28, 2018
Thank you!
Old Jan 29, 2018
Slumpertcivic's Avatar
Burning one quart of oil per 100 yes hundred miles here in Houston...
My son suggested we just start putting oil into the gas tank instead of gas.
cdfccf
Aug 13, 2016 06:36 PM
Absdynamics
Apr 3, 2012 01:09 PM
MRACING
South Cali
Jul 19, 2010 02:25 PM
bugzila
Jun 5, 2006 02:38 AM
torqen2k1
Mar 31, 2004 06:11 PM
