01 Civic bogging at 3000 rpms
Old Jan 7, 2018
Carlos24's Avatar
Carlos24 is an unknown quantity at this point
Put a new motor in my Civic cranks up fine but when driving around 3000 rpms it's starts to bog bad . Feels like it's hitting red line . Any idea on what the issue could be . Thanks in advance
Old Jan 7, 2018
Re: 01 Civic bogging at 3000 rpms
your engine light should be lit.
take to autozone or some auto part store and have codes read.
Old Jan 8, 2018
There's a good chance you forgot to plug a sensor in.
Just so everyone's on the same page, did you swap in the same model engine (D17A1 if you have an LX/DX, D17A2 if you have an EX). If you swapped in a D17A1 and your originally had a D17A2, your car will go into limp mode (rev limit ~4000 RPM) since the ECU isn't reading any VTEC signals. Just one thing that can cause that.
Nevertheless, if your check engine light is, in fact, on, do what sdaidoji said and get the code read. Report back with the code and we can help direct you on your next course of action.
Old Jan 8, 2018
Slumpertcivic's Avatar
Or... if you put a vtec engine into a lx or dx, it will lose power at that rpm range because the vtec selenoid needs to be switched on to move the valve timing to high rpm.
I don’t think it will create a code as the computer won’t understand why the engine has run out of breath.
Old Jan 8, 2018
If you put a NON-VTEC engine into a car that needs a VTEC engine, the original PCM does not like that.
What are the fault codes?
Old Jan 9, 2018
Carlos24's Avatar
Got it fixed guys thanks had 3 codes Iacv intake manifold sensor and the tps . I swapped all the parts from the old motor and it works great now .
Old Jan 9, 2018
Carlos24's Avatar
Got it fixed guys had 3 codes tps Iacv and intake manifold sensor . I swapped all the parts from my old motor and it runs great now . Thanks for the help .
Vin Mendoza
Oct 31, 2017 07:30 PM
Alex519
Mar 22, 2017 01:21 PM
Ochoa1991
Mar 1, 2016 12:01 PM
rileyb22
Dec 6, 2011 04:42 PM
ELTsanwich
Dec 20, 2002 12:36 AM
