Replacing a clutch
Replacing a clutch
So I need to replace a clutch.
I am about to buy this :
EXEDY KHC09 OEM Replacement Clutch Kit
Is there anything else I need to have for the mechanic?
And what do you think they would quote me for labor for a 2002 Honda Civic SI clutch replacement ?
I am thinking 600$ What do y'all think ?
Re: Replacing a clutch
https://www.amazon.com/EXEDY-KHC09-O.../dp/B001B5EEGE
Consider them "Cheap insurance" against axle leaks, especially since they will be disturbed in the course of the work.
You should also get/send a couple quarts of Hondas manual trans fluid to your mechanic.
That's the part number I supplied in another thread. Took it directly from exedy's website. Should come with everything you need for a clutch swap: friction disk, pressure plate, input shaft bearing, throwout bearing, alibgment tool. Extra crap like ezone said wouldn't be a bad idea, but you mechanic would definitely be the one to ask for certain.
anibis
Nov 1, 2011 05:32 PM
Minuscule
May 2, 2007 11:06 PM
Metallica454
15
Oct 12, 2004 04:31 PM
