Filling coolant with block empty
Old Dec 24, 2017
stault's Avatar
stault is an unknown quantity at this point
I'm doing my first head gasket on my 2004 civic ex and what would be the best procedure for refilling the coolant system, and start up procedure
Old Dec 24, 2017
Slumpertcivic's Avatar
Re: Filling coolant with block empty
Besides standard.
Jack front end up so that radiator is higher than engine.
Fill as much as you can.
Start car, turn on heat, hold at 2000 rpm for a minute turn off car.
fill radiator again, put on cap, fill overflow bottle to cold mark.
Drive in neighborhood until engine is fully warmed up with heat on, pull into driveway, let it idle till you,hear the cooling fan kick on then rev it to 2000 rpm for another minute then shut down.
Once it’s cooled down, check level in overflow and under cap. If you need to add more than 12ounce coke can, consider repeating.
Clearly keep checking level daily before driving until your Sure it’s staying full.
Old Dec 27, 2017
stault's Avatar
Thanks, back on the road, everything working
eswar_ner
Oct 8, 2014 06:12 PM
Hoochrulez55
Sep 20, 2013 01:02 PM
nyyanks81
Aug 17, 2005 08:06 AM
alloriginal
Mar 17, 2003 04:03 PM
Kill
May 11, 2002 05:37 PM
