Headgasket replace or new motor ?
Old Oct 9, 2017
Newbie Civic's Avatar
Newbie Civic is an unknown quantity at this point
Headgasket blew on my 04 Civic with 98k 1.7L on it. Which would be better replacing it or the swapping in new motor ? A lot of shops won’t even give me a quote bc they said they just place the motor in it bc the bottom end would eventually go out. The tempurature never got over 3/4 on the temp gauge. Compression is still good in it. Forgot the actual numbers.
Old Oct 9, 2017
Re: Headgasket replace or new motor ?
I'll do head gaskets all day long.
Any used engine you get will probably need a head gasket too.
Old Oct 9, 2017
That’s what I was going to do just wanted to ask other Honda owners their opinions thanks !
Old Oct 9, 2017
I'm not your average owner here.
The main times I don't want to do a head gasket job is when an owner overheated the engine and kept on trying to drive it until it quit running on its own.
Or if it's been hydrolocked.
Or if it's been mixing coolant in the oil and slowly eating the bearings.
There's always the possibility of finding out stuff that can't be predicted (see riceboy's thread), you just have to take it apart to find out if there's a good reason to not fix what you have.
Old Oct 17, 2017
dsm482's Avatar
dsm482 has a spectacular aura aboutdsm482 has a spectacular aura about
or you can start burning oil after headgasket because oil rings got stuck
Old Oct 17, 2017
Car pronounced dead
Cause of death
