2005 Honda Civic Alarm
Old Sep 30, 2017
Arnie's Avatar
Arnie is an unknown quantity at this point
Hi can someone help,
my battery got flat this morning.
Found the fuse 9 drawing lots of current whilst all the functions in the car are off.
ive recharged the battery but when try to put the fuse 9 back, the alarm keeps sounding.
With out fuse 9, the radio isn't working. and door locking and unlocking are not working too.
Thank you.
Old Sep 30, 2017
Re: 2006 alarm
Post moved....
Year of car? Body style and code? Factory alarm or aftermarket install?
Country--GB--your cars may not be quite the same as in North America
Fuse 9, what circuit is that labeled as?
The alarm is probably going off because it was armed when the battery died. Now you need to disarm the alarm to make it STFU.
Remove the horn relay from the fuse box so the horn doesn't wake up the neighbours.
Install the fuse. The alarm will still blink the lights. Unlock the car using the transmitter or stick the key in the door and lock/unlock it. If one door has no effect, try the other door and maybe the trunk lock too.
Some of the cars will disarm after you turn on the ignition, some don't.
Old Sep 30, 2017
Arnie's Avatar
Re: 2006 alarm
Hi
Thanks for your reply
the car is Honda Civic, hatch back, 1.6 petrol, registered 2005.
Ill try to fix it tomorrow morning.
thanks.
nelsona
Apr 4, 2016 11:00 PM
Jack_Maehoffer
Apr 2, 2016 04:41 PM
Jeff Han
Mar 29, 2016 04:48 PM
beeson76
Mar 27, 2016 08:19 PM
nophilangie
Mar 27, 2016 09:40 AM
