Wiper Blades being funky.
Old Sep 6, 2017
thornygravy's Avatar
Car Audio Inc
thornygravy is an unknown quantity at this point
Ever since I got this car, the wipers haven't worked right. I assumed the ones that were on from the previous owner probably weren't all that great so I replaced em with some Bosch Icons.. I balled out lol.
I've spent a couple hours trying to bend the arms carefully, every which way and of course I ended up making the problem worse. They just skid/skip all over the place and the rare time I get a clean wipe (hah) There's this huge fog layer after.
Anyways, looks like I've done all I'm capable of so time to take it to someone else. Just curious if this is a job the local mechanic can handle, or would I be better off taking it straight to Honda?
I have pretty severe ADHD so it's kind of crucial I get this fixed, for the safety of myself and others.
Old Sep 6, 2017
Wankenstein's Avatar
Re: Wiper Blades being funky.
Here's what Goog's says: https://www.google.com/search?q=01+0...k1.U8jCQg5T0XA
Also, found this on a thread: "That problem is not normally a problem with
arm tension arm tension
. It is caused by the pivots of the different sections of the blade. Take the blades off and clean all pivots goodwith wd40 to flush all the dirt.salt out and then lub with spray silicon. Make sure all pivots work freely. Also make sure the rubber blade slides freely in their brackets and are not pushed in on the ends."
Old Sep 6, 2017
Clean the windshield with rubbing alcohol?
Old Sep 7, 2017
Car Audio Inc
Also, found this on a thread: "That problem is not normally a problem with arm tension. It is caused by the pivots of the different sections of the blade. Take the blades off and clean all pivots goodwith wd40 to flush all the dirt.salt out and then lub with spray silicon. Make sure all pivots work freely. Also make sure the rubber blade slides freely in their brackets and are not pushed in on the ends."
Thanks for the input. I'll definitely try this, can't hurt I don't think.
As far as the rubbing alcohol thing, It's usually what I do. I wipe everything down with rubbing alcohol I'll get like 2 good wipes then **** just start chattering and skipping again.
Only time it doesn't seem to happen is when there's like a monsoon out and the whole windshield is soaked between wipes.
Old Sep 7, 2017
Claybar the windshield?
Rain-X the windshield
Ear plugs
Rub DRY graphite powder into the rubber of the wiper blade?
Blades that fit too loose on the arm (the loop on the end of the arm) can chatter, so can poorly built blades (no matter how much they cost).
Blades that only chatter in one direction--might need the arm twisted so the blade sits 90* to the glass, that way it will "flop" an equal amount on either stroke. It has to drag the rubber strip, it can't be trying to 'push' the rubber.
Factory blades were probably NWB brand. Everything aftermarket seems to be a crapshoot experiment LOL
