Need help with AC problem
Old Aug 18, 2017
deanh22a's Avatar
deanh22a is an unknown quantity at this point
2001 civic lx
My AC stopped blowing cold. It still works slightly, but the air is just barely cold. I checked to make sure the compressor was still working (it was). The clutch is kicking in and the fan is blowing. Checked the low pressure - it was good. I didn't feel like taking it into a shop so I just replaced the evaporator, drier, condenser, and expansion valve because it hadn't been serviced in a long time. Basically everything got replaced except the compressor. Then it got weird when I was recharging it. With the ac on, It only took about 6oz of refrigerant before the gauge was telling me the low side was full. When I press the accelerator, the pressure goes down to zero. When I let off the accelerator and idle again, the gauge shows the ac is full. But it should take a lot more refrigerant than that to fill it. Could it be some kind of electrical problem, or is that something that can be caused by a faulty compressor even though it's compressing and heating the refrigerant like it's supposed to?
