Door vapor barrier/plastic film adhesive
Old May 21, 2017
eddie1976's Avatar
eddie1976 is an unknown quantity at this point
I recently replaced a faulty window regulator on 2004 civic. Easy enough...but the adhesive that attaches the white plastic film barrier to the metal door is dried out and wont stick. What do you guys recommend in this case? I want the ability to go back in there if needed. So, willing to pay for the right adhesive that will give me the option to undo the film again in the future (hoping this car will be dead by the time I will need to replace another component in the door).
Thanks!
Old May 21, 2017
Re: Door vapor barrier/plastic film adhesive
I know it's not exactly right...... I've used black strip caulk, and I've used RTV silicone sealer.
I also try to only peel the plastic down from the top so I disturb the bottom as little as possible.
Old May 22, 2017
eddie1976's Avatar
Thanks ezone. I have read using butyl rope or tape is the best replacement. It can be take back off and stays soft in all temps. I think it is sold at homedepot or lowes. I will stop at the local auto place too.
Old May 22, 2017
Colin42's Avatar
Duct tape or tuck tape
Old May 22, 2017
I end up using these because they are handiest in our shop LOL
Old May 22, 2017
eddie1976's Avatar
This is what I ended up buying. I could not find anything locally.
Amazon Amazon
