2001 Acura EL Premium - Front Passenger side power window not working
Old May 9, 2017
jkhattra's Avatar
jkhattra is an unknown quantity at this point
This window stopped working from both driver side master and passenger side switches. I think it happened when trying to open the window during a winter freeze. There was no motor or clicking sound when using either switch. All other windows and their switches worked.
Checked/swapped the 40 amp fuse.
Installed a new motor with regulator. The only moment that the new item worked was when moving either switch up (closing) for the very first time - it moved up the half inch that it was from the top-most position on the track.
Tried the power windows reset procedure. Still no movement.
I unplugged and looked at both window switches and associated wiring. No obvious signs of burn or damage.
What should I try (to learn to test) next? Look at the harder to reach sections of the wiring system? With a multimeter? New switches?
Thank you!
Old May 11, 2017
Re: 2001 Acura EL Premium - Front Passenger side power window not working
Sounds like you're going to want to get a voltmeter and a wiring diagram, and do some real testing to figure out if there's wiring problem or switch problem.
Old May 11, 2017
jkhattra's Avatar
Thanks!
Just what I feared :-(
Okniep
May 8, 2017 03:37 PM
Bum
Apr 13, 2017 06:43 AM
Ryan242
Apr 5, 2017 12:47 PM
trellex
Lighting
Mar 19, 2017 07:02 PM
EV1N3M
Feb 15, 2017 08:15 PM
