[SOLVED] Power Lock/Dome Light/Radio Issue
Old Jan 17, 2017
Tedverseti's Avatar
Tedverseti is an unknown quantity at this point
Exclamation [SOLVED] Power Lock/Dome Light/Radio Issue
Hey guys, I have a 2003 Honda Civic EX (Semi-Noob ). Yesterday, while working on my suspension (completely unrelated), I noticed that my power locks stopped working.
Background Info: I have a Viper alarm system installed on my car. It's been 11 months since that install, and the Viper has never had an issue locking and unlocking the car. When I start the car, the doors automatically lock, as is a feature of this alarm system.
Symptoms:
[Key out of ignition] I sat in my car and proceeded to lock the doors with the switch, on the driver's side door. Nothing. I also noticed that my dome lights, always set to "door", weren't on either. Now, the dome lights worked when I pushed the buttons to turn them on and moved the switch.
[Key in ignition, "On" position] Everything worked normally. Dome lights came on when door opened. Power locks worked.
Because I have an alarm system, I just want to make sure I cover all bases. I suspect the door lock actuator might be going bad, as I heard a noise coming from behind the door panel when locking and unlocking the doors with the switch [Key in ignition]. Are there any fuses I should check for as well, or am I generally looking at the door lock actuator. And if it's the actuator, is it only the driver's side door that requires a new one, or is there one in all 4 doors?
Thanks guys, and sorry in advance if anything above is something I should already know.
Old Jan 17, 2017
Re: Power Lock/Dome Light Issue
Test it!
Then stick a light bulb in the 2 wires that operate the lock motor, see if it lights up when you work the switch
Old Jan 18, 2017
CraigW's Avatar
"Backup" fuse maybe.
Old Jan 18, 2017
^Yeah that^
Good lord, my reading comprehension sucks.
Old Jan 18, 2017
Tedverseti's Avatar
That's EXACTLY what it was. Thanks so much. Wouldn't have thought to check that one. Whoever had my car last put a 20 in that slot, when it really takes a 10. Thanks again.
