2002 wont idle up
Old Nov 10, 2016
whymsk's Avatar
whymsk is an unknown quantity at this point
2002 wont idle up
had my civic under full acceleration. car just died down during pull. engine never cut off but would not pick up speed. if in park or out of gear engine will idle but will not raise above a few thousand rpm. sounds like its speeding up then gets a muffled sound like its starving out. it will back out as if hitting rev limiter. mad the mistake of buying new fuel pump that didn't fix problem. also blew out fuel lines and rail with air gun. have anyone had same problem?
Old Nov 10, 2016
mikey1's Avatar
Re: 2002 wont idle up
i would suspect you have a timing issue,
your timing belt might have "jumped" a tooth or two
Old Nov 10, 2016
Check engine light on? Got codes?
Old Nov 11, 2016
whymsk's Avatar
If it jumped timing will it idle normally? I can drive at low speeds(rpm), but as I give it throttle it jerks and won't accelerate. Had to go through the gears to get up speed to get home. Engine light came on and green key started flashing. Put on small obd tester, but didn't register a code
Old Nov 11, 2016
mikey1's Avatar
did this happen while the engine was running?
if the engine light came on you should have codes stored, even if it went back off
are you saying he green key was flashing while you were driving?
that definitely is not normal
Old Nov 11, 2016
whymsk's Avatar
Yes it all happened while I was driving. I was under full acceleration, then engine backed out hard. Car will start up and run. If out of gear and I give it gas it will rev up a few thousand rpm(guessing no tach) then gets a muffled sound. Engine will rev up and down like hit rev limiter. Green key is flashing on dash and engine light on
Old Nov 11, 2016
engine light on
That's probably not just "no code found", that's probably more like "zero communication with the PCM"
Got a relay clicking madly behind the glovebox when it runs too?
Typical scenario: The alternator was left loose, came loose, broke bolts,or lost its grounding through corrosion.......now it has probably ruined the PCM.
