Fuel Pump and assembly replacement
Old Sep 30, 2016
Yossi's Avatar
Yossi is an unknown quantity at this point
my 02 lx with 197k has a fuel pump going. I am watching the videos and it looks like there is an assembly and within the assembly there is the pump and a filter. It looks a bit complicated to take part to replace just the pump.
I see that they sell the entire assembly for around $150.
Does the assembly typically mean it includes the entire unit with the pump and filter? Is it much simpler to replace the entire assembly? basically just remove the old one, install new one and plug the fuel line and power cable back in?
Also, can you help me with the exact part #? i am finding lots of assemblies with conflicing information as to whether they fit the LX 1.7l, or just the SI.
Old Sep 30, 2016
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: Fuel Pump and assembly replacement
Been working at a honda dealer for more than a decade. I can count on 1 hand how many bad honda fuel pumps I have seen and have 5 fingers left over. Why are you replacing the pump?
Yes, there is an assembly that pull up through the floor of the car that has a pump unit hanging off the bottom of it. That pump can be changed without replacing the rest of the assembly.
I wouldn't trust a parts store fuel pump. If my car needed a pump and I didn't want to spend to pay new honda prices I would use a junkyard/salvage pump.
About the only reason I could see changing a pump is because of water damage or some other contamination. The failure rate of honda fuel pumps is practically zero.
Old Sep 30, 2016
Yossi's Avatar
very helpful - thanks. I am trying to diagnose an intemittent no start situation. battery, alternator, starter all okay. new plugs.replaced fuel pump relay, no CEL. The car always starts up when cold. When the car has been running, and then sitting, even for as short as 2-3 minutes, its 50/50 whether it was start up, or just crank without turning over. If I wait 60 seconds and then try again, it will startup fine.
Old Sep 30, 2016
CraigW's Avatar
What does this mean ??
To me, cranking refers to an engine spinning.
Old Sep 30, 2016
Yossi's Avatar
sorry - might be using the wrong terms. I try to start engine. It goes "chuga chuga chuga chuga" without starting.
Old Sep 30, 2016
Any engine must have compression, spark, and fuel --- in the correct quantities and at the correct times.
So at the moment the engine will not start and run on its own, which of those things is not exactly right?
Got codes?
Old Sep 30, 2016
emich's Avatar
emich is an unknown quantity at this point
check your compression
Old Sep 30, 2016
mcnoople's Avatar
Compression that comes and goes? Doesn't seem likely.
I would be expecting a sensor that has become heat sensitive or a relay that is going bad.
I don't know how handy the OP is with tools. If it was mine I would have a spare ignition coil and spark plug with me for diagnostic purposes. When the no-start occurs unplug the coil on the head and plug its connector into the spare unit with a spark plug installed in the coil pack. Ground end of plug to valve cover and crank engine while watching the plug for spark.
If you have spark that means you need fuel and compression. Compression generally isn't something that vanishes and then comes back later with no other problems.
Old Oct 20, 2016
SlowboyZ's Avatar
SlowboyZ is an unknown quantity at this point
I just did mine not too long ago on an 05 due to leaking
R3KogHyZe
May 26, 2016 12:53 PM
tmst
May 12, 2016 01:14 AM
ChicaPeru7
Apr 8, 2016 12:17 AM
eager2learn
Feb 29, 2016 02:54 PM
vistec
Nov 7, 2001 05:53 PM
