01 Civic not responding to accelerator
Old Sep 19, 2016
tintin20's Avatar
tintin20 is an unknown quantity at this point
I have a 01 Civic EX 5spd Manual. Over the last month or so I have a strange issue every morning when I drive the car after about a mile or so it stops responding to the accelerator. Then if i press it hard the car jerks and responds. If I press the clutch and rev it up it responds but in gear there is no response.
Then if I park the car turn it off wait 10 seconds and turn it back on there is no issue until the next day. Any ideas?
Oh.. and there are no check engine lights except once when the CEL turned on and the code was for the primary O2 sensor which turned off bu itself in a day or so.
Old Sep 19, 2016
Re: 01 Civic not responding to accelerator
Unplug that primary sensor and drive it, see if the problem does not happen while the sensor is unplugged.
Old Sep 19, 2016
tintin20's Avatar
So it happened again today. and I just pressed really hard on the accelerator and it jerked a little and then worked fine.. but the CEL is now on.. So I will unplug the sensor cable tomorrow and see what it does...
Old Sep 19, 2016
Before unplugging the sensor it did this?
What's the code now?
Old Sep 22, 2016
tintin20's Avatar
Been driving with the sensor unplugged.. CEL is on but there are no problems now. So I think I need a new O2 sensor..
Old Sep 22, 2016
You did not check new fault code before unplugging the sensor?
If symptom is gone while primary sensor is unplugged, I'd replace the sensor. Use the same brand sensor as original (it will be either DENSO or NTK).
Old Sep 30, 2016
tintin20's Avatar
changed the O2 sensor... and problem is gone... removing it was a PITA though... thanks for the help guys...
Old Sep 30, 2016
Right on, thanks for the update
gregd
Electrical
Jul 23, 2023 04:39 PM
Carolyn Gilbert
Sep 10, 2019 11:58 AM
Skatefrench
Jul 22, 2018 10:11 AM
jackoncruzpr
Sep 4, 2016 07:42 PM
