Car won't start sometimes
Old Sep 10, 2016
Nettie's Avatar
Nettie is an unknown quantity at this point
Hey guys, hoping for some help. I have a 2013 civic, atleast on 3 occasions my car would not start, lights were bright, radio on, I got a jump and it started, assuming it's not battery but was told probably is alternator, I have 60k miles on my car I purchased it October 2013, should alternator go bad so soon or could it be something else. I called dealer $125 to check it, considering taking to auto store to check alternator, any advice would be appreciated, thx!
Old Sep 10, 2016
Poopies's Avatar
Super Moderator
Re: Car won't start sometimes
The alternator charges the battery while the car is running. If the battery was fine when you tried and failed to start, it could be the starter. There could also be a parasitic draw problem, where something is using the battery while the car is off. You could check the battery's voltage with a multimeter after it has been sitting overnight. Cheaper than an alternator!
Old Sep 10, 2016
Nettie's Avatar
🙂 Good Morning, thx for replying, hmm a parasitic draw problem that's a new term for me will look into it.
Old Sep 10, 2016
Usually this means your battery didn't have enough "juice" to start the car.
Either ran down, weak, bad, dead, poor connections, there must be a reason.
Test battery first and replace if necessary.
If that passes test then check if there is excessive drain on the battery (Parasitic draw) when the car is turned off.
Old Sep 10, 2016
Nettie's Avatar
Ezone thx for advising me. I really didn't think it was the battery because everything was lit up the car just wouldn't turn over but I will take your advice and have the battery tested. I appreciate you🙂
Old Sep 11, 2016
Dash lights and stuff that powrrs up with the key on takes a little power.
The starter might need 10 times the power those dash lights needed. If the battery cant supply all of that, it wont crank.
Old Sep 11, 2016
Nettie's Avatar
ok I understand that. In a nutshell I need to test battery first to see if that's the problem then proceed from there. Thx you've been a big help. 🙂
Old Sep 11, 2016
Only 3 times? All like in the last 3 days or....3 times since the car was new?
How long did the car sit untouched (not driven) before it would not start? Overnight? 2 weeks?
Assuming it ran fine and drove around after jump starting, I'm assuming the alternator is doing its job.
Also note, the little handheld battery tester gizmo so many places like to use these days because it gives a nice printout to hand to the customer, they don't always find the bad batteries.
Old Sep 11, 2016
Nettie's Avatar
the first time was several months ago didn't get a jump just to a couple times before it started. 2nd time was late July received a jump, and this last incident was September 4th.
Old Sep 11, 2016
There is far too much time between those 3 events to really conclude a battery failure. Right now that makes me think something ran the battery down.... maybe a map light left on overnight........or like sitting in the car with the key on (engine not running) for more than a couple minutes. (YES people do this a LOT, leave the key on/dash lit up/headlights or DRLs on, while sitting still and run the battery down to the point it can't start)
Most average battery failures would be a constant problem, it would not heal itself and be fine for months longer.
If the frequency of the problem increases in the coming days (needing a jump start daily?) that would be a problem. Assuming no other outside causes of running the battery down.
Can you answer this question?
The reason I ask this one is some failures can cause the battery to self-discharge but that usually takes some time, anywhere from overnight to a few days.
Immediately after recharging, the battery could pass tests, but after sitting untouched for several hours it may fail tests.
Old Sep 12, 2016
Nettie's Avatar
between your suggestions and talking with my son who uses the car and who had the car on each of these occasions, he sits in the car with radio and air on I'm not sure for how long but I'll guess for long enough to cause this problem.
Old Sep 12, 2016
Well....the AC sure won't be cold unless the engine is running, so I think he's gonna have the engine running.
Now if he's in the car playing the radio without running the engine, you may have found the problem.
Old Sep 12, 2016
Nettie's Avatar
i told him not to do it anymore so we'll see if it doesn't happen again that was the problem, I'm going to let you know how things go and thank you so much for your help Ezone 👍🏽 I'm glad I found this forum some great info on here
LanceDMAN
Mar 24, 2016 06:31 PM
mechris
Mar 5, 2016 09:16 PM
onelifetolive
Bolt-on Engine Performance
Nov 10, 2001 10:58 AM
NukeSilo
Nov 4, 2001 09:37 PM
