Air Conditioning Stopped working
Old Jul 3, 2016
Troyditt's Avatar
Troyditt is an unknown quantity at this point
Hey guys!
Im new to this site and new to owning a civic and I am having a problem with my air conditioning. I recently had my compressor replaced, it worked for two days then Stopped and the relay on the compressor had to be replaced. Now after a month it stopped again however this time the fan still runs. I know theres no leak in the system anywhere as it was just at my trusted mechanics shop. Now I think it might be the a/c clutch relay but im not sure. Any suggestions would be a huge help!
Old Jul 3, 2016
Re: Air Conditioning Stopped working
Could be just the clutch itself. There's a shim behind the clutch plate that's (or so I've been told) designed to be removed once the clutch starts to not work as well. So far, from the couple people that have tried it since I heard of this, it works like a charm.
Part labeled 6 on the diagram.
I'm sure ezone will chime in to verify whether or not this is a correct thing to do. lol
Word of caution. That nut (labeled 3) is not fun to take off. I tried an impact wrench with a 14mm socket (correct size, my impact socket's walls were a little to thick to get good engagement on the nut) on it and ended stripping it out a good bit. If you have an angle grinder, the spanner wrench to change out cutting wheels fits on the clutch to keep it still.
Old Jul 4, 2016
There is no relay ON the compressor. The relay is FOR the compressor. It's in the engine compartment fuse box. If the shop got a cheapie and it's only days old I'd expect it to have lasted longer than this.
NEW compressor? NEW relay?
Return to the shop that did the work. They owe you a working system, yes?
It is not DESIGNED to be removed. Removing it is just a cheat to change the clearance.
If the compressor is new this shouldn't be a factor.
Old Jul 4, 2016
Ah, gotcha
Ahboy94
Nov 15, 2015 08:42 PM
41
Nov 11, 2015 09:15 AM
Daleford
Nov 10, 2015 05:41 PM
onelifetolive
Bolt-on Engine Performance
Nov 10, 2001 10:58 AM
