Timing belt tensioner - spring loaded?
Old Apr 27, 2016
CelticOne's Avatar
CelticOne is an unknown quantity at this point
I am replacing the timing belt on my 2005 Civic (1.7l). I have the tensioner off. Is it spring loaded? When I squeeze it closed to put a pin in it there is no pressure - it moves freely. Is this correct or has it failed? Thanks for your help.
Old Apr 27, 2016
Re: Timing belt tensioner - spring loaded?
There should be resistance as the pivot is dampened-- but not internally spring loaded.
The only spring is the external one that hooks between the pulley and a peg on the block.
Old Apr 28, 2016
mikey1's Avatar
it is correct, however, depending on your mileage you might want to replace it anyway
MajTom
Electrical
Oct 16, 2021 08:47 AM
Spencer Morgan
Nov 20, 2015 12:02 PM
bgtg
Electrical
Nov 4, 2015 06:14 PM
danfry21
Oct 31, 2015 02:26 PM
ernie22lord
Oct 26, 2015 12:01 PM
