Transmisson???
Old 10-01-2015
Solo Flow's Avatar
Solo Flow is an unknown quantity at this point
Transmisson???
I have an 02 civic coupe ex i had a blinking D light i got code 0758 solenoid b electrical or faulty but then out of no where it stoped blinkin n driving fine now when i put it in gear i have to shut it back off cuz it didnt grab anythen wen i turn it back on n put it in either d d3 2 it doesnt grab immediately i have to stay on the brakes til i feel alil shimmy shake of the car feeling like the transmission grabing the gear n makes the car trebble just alil bit just for me to feel then i kno i can pull off but as i continue once i stop at a red light or stop sign it lets the gear go n im only revving the engine at this point omg plz dont tell me i need a new transmission
Old 10-01-2015
Elciteeve's Avatar
Elciteeve is an unknown quantity at this point
Re: Transmisson???
What are the fluid levels like? When was the last time you did an ATF change?
Old 10-01-2015
Solo Flow's Avatar
Re: Transmisson???
The fluid smells fine n is a pinkish redish color n ive never done a atf
Old 10-02-2015
emich's Avatar
emich is an unknown quantity at this point
Re: Transmisson???
Start with ATF change
Old 10-02-2015
Elciteeve's Avatar
Re: Transmisson???
You still didn't say what the levels are like. If you have low fluid, your transmission won't function properly.
Since you've never done a change though, I echo emich, start with an ATF change. Not sure if that model has a filter or not, if it does, change that as well.
Old 10-02-2015
Solo Flow's Avatar
Re: Transmisson???
Its seemed to have to much atf so i replaced n took some out n i just put the solenoid on n still no movement omg im pissed
Old 10-04-2015
Solo Flow's Avatar
Re: Transmisson???
This morning i turned on the car n engine still cold i put it in D n my car moved..... But i only moved it about 20 feet forward then put back on park i will try again in a few to see wat happens
Matteo
01-09-2015 11:22 PM
sportsfantic35
06-20-2013 03:35 PM
sportsfantic35
06-17-2013 07:01 PM
jwatts95
02-26-2011 05:14 PM
Msbiles11
03-07-2010 03:00 PM
Quick Reply: Transmisson???
