Bolt-on Engine Performance Modifications Intake, header, exhaust, flywheel, pulley and other bolt on information and questions belong here.
'98 Civic Engine Swap
Old Jun 17, 2013
sportsfantic35's Avatar
sportsfantic35 is an unknown quantity at this point
I own a '98 Honda Civic and I was wondering is you are able to put a manual engine with an automatic transmisson
Old Jun 17, 2013
Re: '98 Civic Engine Swap
As far as the basic engine block and head is concerned, I think the main difference will be swapping the flywheel and pilot bearing with the flexplate from the old engine.
The manifold(s) you should just plan on swapping from the old engine anyway. Throttle body and IAC, electronics are probably different enough to need swapped.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
beneditti
Jan 15, 2016 12:31 PM
usajags84
May 10, 2015 08:11 AM
BREADFAN
Apr 15, 2015 08:58 AM
shawe90
Apr 14, 2015 07:10 PM
