Increased resistance in left side seat belt tensioner
Old Sep 23, 2015
PunX's Avatar
PunX is an unknown quantity at this point
Hey, I swapped in a set of RSX leather seats into my 05 sedan. All's well except my airbag light is now on. Hooked up a code reader and it's giving me the code Increased resistance in left side seat belt tensioner. Cleared it and it came back right away.
The car they were in before mine didn't have an airbag light. Any advice? Thanks
Old Sep 23, 2015
mcnoople's Avatar
The legs in the public bathroom stall
mcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to beholdmcnoople is a splendid one to behold
Re: Increased resistance in left side seat belt tensioner
Did you plug it in? Has the tensioner been deployed?
Sometimes this code is set be a very very small amount of corrosion on the terminals in the connector. Other times it can be a pin-fit issues which is when the female terminal is spread out and not griping the pin properly.
The service info will tell you to not measure the resistance of tensioners and inflator due to the risk of accidental deployment.
Old Sep 23, 2015
What is the actual code number?
HINT: "Belt" is not the same as "buckle". Think about it.
Old Sep 23, 2015
PunX's Avatar
3-2 Increased resistance in left side seat belt tensioner
I'll look into this, thanks.
Is it possible to use the buckle assembly off of my stock seats with the rsx seats? Thanks
Old Sep 23, 2015
Read this again:
Won't do any good.
It's not a buckle problem.
EdGasket
May 25, 2015 01:06 PM
jimmyfloyd
May 20, 2015 07:06 PM
bsmiley
Apr 27, 2015 01:27 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
JackTripper
Nov 7, 2001 09:04 PM
