Starts then dies!!! Help
Old Sep 22, 2015
68camerors's Avatar
68camerors is an unknown quantity at this point
Question Starts then dies!!! Help
My daughters 04 starts only with cps unplugged. Checked voltage on blue wire and get about 5v. The voltage stays constant, plugged up to cps or unplugged to cps. The crank position sensor is new. Also the 5v doesn't change when engine is turned by hand. Please help.
Old Sep 22, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
Re: Starts then dies!!! Help
Is this a Honda CPS?
Have you checked the service manual, which I have posted for your viewing pleasure?
The service manual includes some steps where you check measurements to the ECU.
Old Sep 22, 2015
What does it do when this is plugged in?
Start --then die in 2 seconds? Timing belt has jumped time.
EDIT: Wait a sec...What are you calling a CPS??? Cam position sensor (CMP) or Crank position sensor (CKP)??
Old Sep 23, 2015
68camerors's Avatar
Old Sep 23, 2015
68camerors's Avatar
how do I see steps?
Old Sep 23, 2015
Where are you taking your voltage reading on the blue wire?
At the PCM, or are you backprobed into the backside of the CKP connector?
Did you verify the integrity of the ground on the brown/yellow wire?
Have you carefully inspected the condition of the terminals inside the CKP connector?
The connector may be prone to moisture entry and terminals are subject to corrosion damage.
Also check the terminal tension, or "grip" of the female pins in the connector.
Old Sep 24, 2015
68camerors's Avatar
voltage taken on blue wire while plugged up AND while unplugged 1 inch from connector.
good ground and 12v. on other wires. I get constant 5v. like its getting 5v from another sensor. Does the constant 5v tell pcm to shut down? if so where is this 5v coming from?
Old Sep 24, 2015
68camerors's Avatar
Old Sep 24, 2015
You should see a 12v, a ground, and a 5v. (not sure about the order, I did not check a diagram)
The 5v comes from the PCM (bias voltage) on the CKP input line, the sensor should pull it to ground as the "trigger bumps" move past the sensor.
Is the crank pulley installed backwards somehow (IDK if that's even possible)?
Do the triggers line up with the sensor correctly?
Is the sensor alignment peg broken off, sensor misaligned or not close enough to the gear teeth?
Wild Cranker
427
Jan 28, 2016 06:49 PM
mrcell24
May 19, 2015 10:02 AM
Ashley Farr
May 7, 2015 05:01 PM
twtron
Apr 17, 2015 12:09 AM
black2k1vtec
Dec 6, 2001 09:49 PM
