Rough Shaking Idle (occasionally)
Old Aug 19, 2015
lyanreindecker's Avatar
lyanreindecker is an unknown quantity at this point
Hey, I have a 2002 honda civic with a d17 series in it. Its got 270,000 on it. Recently its developed a rough chugging idle, sounds like its not running on all cylinders. I've taken the old plugs out and they don't seem to be fouled or in terrible shape, the new plugs will go in tomorrow. It only shakes at idle sometimes and the rest of the time it will smooth out, plus it smooths out with acceleration. When it starts chugging the tachometer doesn't move. Any idea what this could be?
Old Aug 20, 2015
Reverb2005's Avatar
Reverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of lightReverb2005 is a glorious beacon of light
Re: Rough Shaking Idle (occasionally)
Does it only happen during idle?
Is the check engine light illuminating at any point?
Yes and no to those questions respectively would point toward the idle air control valve (IACV), though you can get a code for the IAC valve, just not always.
Usually a cleaning or complete replacement solves the issue.
Old Aug 20, 2015
The check engine light is not on and it happens during idle but also chugs a little bit until the car revs up to around 2500. When I first start it up it will run smooth and only idle rough some of the time but it seems the to get progressively worse the longer you drive.
Old Aug 20, 2015
Reverb2005's Avatar
There are some other possibilities but the IAC valve is pretty simple to get at and clean out.
If cleaning it doesn't work, you may need a new one as cleaning doesn't always solve the problem.
There is a good write-up about some common fixes, including the IAC valve here:
https://www.civicforums.com/forums/1...e-up-mods.html
Old Aug 20, 2015
bsmiley's Avatar
bsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nicebsmiley is just really nice
After you clean IAC do an idle learn.
pizzahutcombo
Suspension
Jul 13, 2021 09:41 PM
SimpleUser
Apr 24, 2021 02:54 AM
alaga
25
Aug 13, 2015 04:42 PM
amrhamed
Aug 7, 2015 11:39 AM
1khilari
Jul 9, 2015 08:12 PM
