A/C Problem
Old Aug 15, 2015
4jacks's Avatar
4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light4jacks is a glorious beacon of light
A/C Problem
2002 Honda Civic HX, 215k miles on body, swapped engine to JDM at 180k miles.
The A/C is blowing hot air. I got a can of 134a refrigerant to refill it. The can has a pressure gage on it that reads from 0 kPa to 80 kPa. I turn the car on and put the A/C to full blast and leave the car running. I open the hood and attached the can of refrigerant to the low side port. The pressure gage immediately spikes off the chart beyond 80 kPa. I can tell that no refrigerant is leaving the can because the can is not turning cold.
Any clue what this means?
Old Aug 15, 2015
Re: A/C Problem
That means it was not a freon problem.
You need to pursue electrical stuff instead.
When you turn the AC on do the radiator fans kick on?
Old Aug 16, 2015
4jacks's Avatar
Re: A/C Problem
No the Radiator fans do not turn on, I thought that was odd, but wasn't sure
Old Aug 16, 2015
Re: A/C Problem
Wait wait wait..... google converter says 80kPa = 11 PSI?
You SURE your gauge reads in kPa?
Old Aug 16, 2015
4jacks's Avatar
Re: A/C Problem
Errr you're right PSI on outside, kPA inside
top of gauge is 552 kPa = 80 PSI
Old Aug 16, 2015
Re: A/C Problem
80 is plenty of pressure to get the system to start operating.
Disconnect the 3 wire connector from the compressor, and ohm test between the outer two red wires. There should be continuity.
EDIT: The center wire operates the compressor clutch
Pull the connector off of the pressure switch, start the engine turn the AC on and check if there is a ground on the blue wire.
Old Aug 17, 2015
4jacks's Avatar
Re: A/C Problem
Thanks EZone. I made an appointment with the shop for Friday. Not looking forward to the repair bill, but I haven't ever really messed with A/C repairs before, and in my townhouse I'm working with limited space and tools.
mikemc422
Aug 9, 2018 05:41 PM
cukaracha
Jun 4, 2015 07:47 PM
g4384063
May 30, 2015 11:21 AM
dinsum
May 28, 2015 09:30 PM
beveragemp
May 25, 2015 07:11 PM
