Oil Leak Head Gasket
Old Jun 13, 2015
jdawgzcivic's Avatar
jdawgzcivic is an unknown quantity at this point
Hello,
I had my 2003 Honda Civic LX Coupe serviced and the head gasket was replaced (blue) and sealed. Now, I'm noticing little drip of oil from the
"black" round piece on the picture. What is this part called? How come the dealership did not change this part as well when they installed a new head gasket (blue)?
Will I be able to replace that part myself? or does the entire head gasket need total breakdown again?
Can I also use this "gasket maker" around that "black" round piece to seal it?
I appreciate all feedback and suggestions.
Thanks in advance.
JD
Name:	Hoonda Civic 2003 Oil Leak.jpg
ID:	87786   Click image for larger version
Name:	Gasket Maker.jpg
Old Jun 13, 2015
Re: Oil Leak Head Gasket
Replace the plug, it's like $9.
Honda part #12513-P72-003
It is not part of a basic head gasket replacement job.
And that blue gasket is the valve cover gasket (or called cylinder head cover gasket), not a head gasket.
Old Jun 13, 2015
Awesome. Great to know and I will be able to do it myself without going to dealership?
I also have to use it with the HondaBond Silicone Liquid Gasket?
So for any future leaks, I can use this HondaBond too?
Thanks
Old Jun 13, 2015
Pry the old one out, push the new one in.
It's that simple.
When you pry the old plug out at least one of the plastic hooks will probably snap off, so try to fish out the broken piece(s) if you can.
The plug has an O ring embedded in it, the O ring does the sealing.
Additional sealers aren't necessary but some people like to smear that stuff everywhere. I don't.
HTH
Old Jun 13, 2015
Ok, thanks again.
Will the new one come with the "O-ring" as well? or have to order the O-ring separately?
Thanks
Old Jun 13, 2015
Originally Posted by jdawgzcivic
Ok, thanks again.
It comes as one piece, O ring is built into the plug.
#6 is the plug:
Old Jun 13, 2015
Good stuff - appreciate your help.
Thanks again
Old Jun 27, 2015
Thank you! Thank you! Thank you very much for your help.
After a week after installing, no more leaks.
Really appreciate your help.
The auto repair place I went to could never fix it and wasted several hundreds and will never go back there again.
Another issue I've been noticing lately is the smell from the AC unit. I changed the cabin filters and also the filter on the engine.When the AC is turned ON, you can smell like dead leaves or this unusual smell blowing out. What else can I change or look for to fix this issue of the smell from the AC?
Thanks again. Appreciate your help.
Old Jun 27, 2015
There really could be dead leaves and whatnot in the cowl area at the base of the windshield. This is where the blower draws its fresh air.
Old Jun 28, 2015
alex_nyc's Avatar
alex_nyc is an unknown quantity at this point
Thanks
I need a T-shirt That say that!!
..and its Stealership not dealership!!!
Old Jun 28, 2015
As a dealer tech, I resent that comment.
(I know why the term is used though...Sad but, more often than not, true.)
Old Jun 30, 2015
Where can I find or locate these? Is this under the hood? I've tried but not sure what I'm looking for under the glove compartment area?
Thanks
Old Jun 30, 2015
Thanks
Maybe I should have called it the wiper cowl? It's the area where the wiper linkage and motor are hidden.
If you had to replace the wiper motor, you would have to get into the plastic panels between the hood and windshield. This same large somewhat hollow area is where the blower gets its fresh air.
I assume your smell is mostly when using fresh air, and smells ok when using recirculate?
If it smells bad all the time including when set to recirculate, there are products available to help disinfect the evaporator and HVAC case.
brian257
Jun 4, 2015 08:17 PM
Jun 2, 2015 11:54 AM
zaboomafoozarg
May 30, 2015 09:21 AM
davidpaustin
May 20, 2015 12:59 PM
HondaHomer
May 14, 2015 12:24 PM
