Any Suggestions on Take Off SHUTTERING
Old May 21, 2015
mom2nathan's Avatar
mom2nathan is an unknown quantity at this point
Smile Any Suggestions on Take Off SHUTTERING
I have a 2014 Civic that I have put 10000 miles on. Notice on take off about 50 percent of the time it shutters when going to that first gear and usually when turning to the right. I thought transmission but have no idea. Aware that it is under warranty but it will take a miracle for them to acknowledge and fix. Please help.
Old May 21, 2015
Re: Any Suggestions on Take Off SHUTTERING
Go to the dealer with your complaint.
Take the tech or advisor for a quick test drive and DEMONSTRATE your issues so everyone is on the same page, so there is no guessing.
Plan on staying for a little while...
While you are there, go to the front lot and Test Drive a couple other identical Civics for comparison to yours.
Some vibration may be considered average, but some may not be normal.
Someone (tech) may need to compare with a few other cars first before deciding yours has a problem worth pursuing.
No, there may not be a fix if other cars compare about the same as yours, but your issues/complaints probably need to be documented.
I don't see any service bulletins under engine or transmission regarding the issue at this point.
HTH
Old May 21, 2015
mom2nathan's Avatar
thanks, will do. my dealer usually shrugs off issues so thought I would go in with a possible solution.
Old May 21, 2015
Sorry, I have none. I've seen little or no issues with Civic CVTs so far at my dealer.
I have seen a couple complaints about other cars though.
Most people are worried about how it acts because they are so used to a regular automatic trans, this CVT is just -- different.
Maybe Hondas technical support department has other information that techs don't have access to.
Old May 21, 2015
mom2nathan's Avatar
thank you too. Ok, maybe it is the CVT that I am not used to but I would think it would do it every time. It is just weird the way it feels like a transmission shutter.
UltraHDGames
Jun 8, 2016 05:16 PM
solarpunk70
Apr 12, 2016 11:43 AM
juicetayne
Sep 30, 2015 11:02 AM
anubis62
Sep 27, 2015 12:56 AM
J-Fly
Sep 10, 2015 08:39 PM
